MPDano's Avatar
Smog Pump rebuild?
Can it be done or is there a company that does it. My Smog Pump siezed on my Euro today. It had a real bad bearing noise prior.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 07-11-2011, 09:08 PM
Network Native
Danglerb's Avatar
Place on ebay wants $100, looks like the same place maybe in Mira Loma that has the water pump parts.
Google hits a few threads of DIY rebuilds, be careful with the vanes, and replace the bearings, some took it to an alternator shop to get the bearings pressed.
Old 07-11-2011, 11:13 PM
Pete R's Avatar
(when I had one) I changed the front bearing on mine. The one in the rear was odd and couldn't be matched and i couldn't find a pn for it. So I just lubed it and threw it back together.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 07-12-2011, 03:57 AM
MPDano's Avatar
Thanks guys. eBay sounds tempting. I may take mine out and see how hard it is to replace the bearings myself. Or maybe not.
It was kind of a show last night when it seized up, screeching noise then lots of smoke as it fried my Pump Belt.
Old 07-12-2011, 05:41 AM
Pete R's Avatar
If it seized it may not be the bearings. There are spring loaded vanes inside, IF they wore down enough they may have come out of there slot and wedged agaist the housing. You can have my gutted one if you want.. (doesn't pump air)
Neon SRT4 track car
Old 07-12-2011, 05:45 AM
MPDano's Avatar
Much thanks Pete on the offer. I think I will just get mine rebuilt. Seems like a good deal and I need to stay Calif Smog Nazi Compliant
Old 07-12-2011, 05:48 AM
928: Serial Enabler
I've got one making a lot of noise.
Please post how you solve it!
84,85,86 928 cars
Old 07-12-2011, 06:18 AM
Petie3rd
Mrmerlin's Avatar
NOTE the smog pump may be damaged with water or chemical cleaners ,
be careful about washing the pump as usually the front bearing can seize,
if you do get the pump wet then add some engine oil to the front shaft prior to spinning the pump.
Note the vanes should not be lubricated as they are supposed to run dry
Old 07-12-2011, 06:31 AM
No Need to work on them >
Water Pumps and Smog Pumps are so Inexpensive
Now I no a lot of People on this forum well disagree ? and they only like NEW ! Bla Bla Bla
But I have used these Pumps and they work just fine and have a 1 year warranty
Link
Auto-Pac/Dragon-up-pumps - Home
MY PUMP WORKS FINE IT IS QUITE AND NO LEAK ETC . >>
I have used these Pumps for some time and I know a Porsche Business that has used them for a long time with no Problems
Note : email is a good way to contact them >>
You can send in your core and they well rebuild it fast > Like Water Pump $100 with Ceramic Impeller
Old 07-12-2011, 08:51 AM
Network Native
Danglerb's Avatar
Link
Huh, Riverside not far from where I used to live, or far from Mira Loma, wonder if the companies are related.
Old 07-12-2011, 05:14 PM
Recovering dismantler
neil30076's Avatar
Same company - I have researched them before - chinese rebuilder. IIRC the riverside drop off address is almost a drop box at a recycling depot.!
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 07-12-2011, 05:27 PM
SanDiego928's Avatar
Leo, How did this turn out?
My smog pump bearing is in a bad way, just happened. After the engine gets to idle with sporadic noise. Restart, and I get a 1 knock sound then bearing noise continuously.
Mark
1981 928
Old 06-22-2013, 03:12 PM
MPDano's Avatar
I honestly don't remember. I think I just found one used on eBay. My Euro has been down for so long, I forgot I even had this issue.
Old 06-22-2013, 03:25 PM
Thanks leo. Just was wondering.
Issues. I got a few.
Old 06-22-2013, 06:11 PM
rjm65's Avatar
Hey Mark,
Here's what I did on my 79 when I had to replace the air pump.
Raymond
Low Buck Alternative Air Pump
Raymond
1979 928 5 spd
Old 06-22-2013, 07:21 PM
Network Native
Danglerb's Avatar
I like to at least try and rebuild everything on a 928 I get a chance to, see what I can learn.
Old 06-22-2013, 09:06 PM
Thanks Raymond for the link. I did read your posts and then looked at 928intl and 78-79 are listed as separate pump than the 80-95 so I wasn't sure at that point.
Thanks Mike for the push. If I had the time I would and am thinking about it. My present work and chores out weigh my desire to accomplish this right now but.......
.....A friend did offer me this 84 Euro smog pump. Would this fit? If it spins is it good to go?
Mark
1981 928
Old 06-23-2013, 06:51 PM
MPDano's Avatar
I do remember that I was able to pass smog without the smog pump pumping air into my Cat. My Euro is a special case as I put a US motor in it and it has all the Euro CIS. Heads are different so when I had the Diverter Valve pumping air into the head, I caused a huge air leak. I put a block in the vac line that controls the Diverter. With how well the new Cats are, you really don't need the pump anymore. You could remove the innards of the pump, slap a new bearing in it and be done.
Old 06-24-2013, 06:02 AM
Thank you Leo!
Mark
1981 928
Old 06-25-2013, 11:55 AM
