Smog Pump rebuild?
Can it be done or is there a company that does it. My Smog Pump siezed on my Euro today. It had a real bad bearing noise prior.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Network Native
Place on ebay wants $100, looks like the same place maybe in Mira Loma that has the water pump parts.
Google hits a few threads of DIY rebuilds, be careful with the vanes, and replace the bearings, some took it to an alternator shop to get the bearings pressed. |
(when I had one) I changed the front bearing on mine. The one in the rear was odd and couldn't be matched and i couldn't find a pn for it. So I just lubed it and threw it back together.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Thanks guys. eBay sounds tempting. I may take mine out and see how hard it is to replace the bearings myself. Or maybe not.
It was kind of a show last night when it seized up, screeching noise then lots of smoke as it fried my Pump Belt.
If it seized it may not be the bearings. There are spring loaded vanes inside, IF they wore down enough they may have come out of there slot and wedged agaist the housing. You can have my gutted one if you want.. (doesn't pump air)
Much thanks Pete on the offer. I think I will just get mine rebuilt. Seems like a good deal and I need to stay Calif Smog Nazi Compliant
928: Serial Enabler
I've got one making a lot of noise.
Please post how you solve it!
84,85,86 928 cars |
Petie3rd
NOTE the smog pump may be damaged with water or chemical cleaners ,
be careful about washing the pump as usually the front bearing can seize, if you do get the pump wet then add some engine oil to the front shaft prior to spinning the pump. Note the vanes should not be lubricated as they are supposed to run dry
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
No Need to work on them >
Water Pumps and Smog Pumps are so Inexpensive Now I no a lot of People on this forum well disagree ? and they only like NEW ! Bla Bla Bla But I have used these Pumps and they work just fine and have a 1 year warranty Link Auto-Pac/Dragon-up-pumps - Home MY PUMP WORKS FINE IT IS QUITE AND NO LEAK ETC . >> I have used these Pumps for some time and I know a Porsche Business that has used them for a long time with no Problems Note : email is a good way to contact them >> You can send in your core and they well rebuild it fast > Like Water Pump $100 with Ceramic Impeller Last edited by aluminum; 07-12-2011 at 08:55 AM.. |
Network Native
Recovering dismantler
Same company - I have researched them before - chinese rebuilder. IIRC the riverside drop off address is almost a drop box at a recycling depot.!
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach Last edited by neil30076; 07-12-2011 at 05:30 PM.. |
Leo, How did this turn out?
My smog pump bearing is in a bad way, just happened. After the engine gets to idle with sporadic noise. Restart, and I get a 1 knock sound then bearing noise continuously.
Mark 1981 928 |
I honestly don't remember. I think I just found one used on eBay. My Euro has been down for so long, I forgot I even had this issue.
Thanks leo. Just was wondering.
Issues. I got a few. |
Hey Mark,
Here's what I did on my 79 when I had to replace the air pump. Raymond Low Buck Alternative Air Pump
Raymond 1979 928 5 spd |
Network Native
I like to at least try and rebuild everything on a 928 I get a chance to, see what I can learn.
Thanks Raymond for the link. I did read your posts and then looked at 928intl and 78-79 are listed as separate pump than the 80-95 so I wasn't sure at that point.
Thanks Mike for the push. If I had the time I would and am thinking about it. My present work and chores out weigh my desire to accomplish this right now but....... .....A friend did offer me this 84 Euro smog pump. Would this fit? If it spins is it good to go?
Mark 1981 928 |
I do remember that I was able to pass smog without the smog pump pumping air into my Cat. My Euro is a special case as I put a US motor in it and it has all the Euro CIS. Heads are different so when I had the Diverter Valve pumping air into the head, I caused a huge air leak. I put a block in the vac line that controls the Diverter. With how well the new Cats are, you really don't need the pump anymore. You could remove the innards of the pump, slap a new bearing in it and be done.
Thank you Leo!
Mark 1981 928 |
