-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   t-stat failure design (http://forums.pelicanparts.com/porsche-928-technical-forum/759101-t-stat-failure-design.html)
lfausty 07-03-2013 07:37 AM
are the typical/stock tstat designed to stay open when/if fail?. is there one that will stay stuck open if fail?.
Danglerb 07-04-2013 01:00 AM
I think there is some difference between years, but as the Tstat heats up the plunger blocks a bypass so the flow is through the radiator. Not sure if there is a way it always fails, but fail = overheat sounds bad.
