auto tranny vacuum
I have a '84 928s auto that's shifting a little strange, i'm sure its vacuum related or hoping so ,I have a three prong connector on top of the bell housing at the back of the motor, cant find where it goes? i'm famliar with vacuum modulators on American trannys & have tailored many to my specific shift points. it shifts very positive through every gear, but at times I have to lift off the throttle to get it to shift? I appreciate any help thanks steve
Old 07-14-2013, 10:40 PM
Mad scientist
Peter Bull's Avatar
The transmission on my '91 S4 had a similar behavior that was solved by adjusting what the workshop manual called the "throttle pressure cable". It is a cable that runs from the throttle linkage on the engine to the transmission. If the play in that cable is too big, or too small, the shifting gets strange.
HTH
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 07-15-2013, 12:59 AM
MPDano's Avatar
This is a known issue on earlier 928's. There is a small vacuum line (which disintegrates) and connects to a hard line that follows the torque tube and there is another small line that connects to the transaxle. Replace those two and you'll be golden.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 07-15-2013, 06:19 AM
harborman's Avatar
"I have a three prong connector on top of the bell housing at the back of the motor, cant find where it goes?"
That might be for the ignition timing pick up.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 07-15-2013, 08:20 AM
