Dadddio's Avatar
reverse bleed
I am going to reverse bleed my brakes and clutch.
Is there a specific order that I should go in?
Old 08-06-2013, 07:46 AM
Petie3rd
Mrmerlin's Avatar
why and what exactly does reverse bleed mean
correct bleed procedure is MC ,LF,RF,LR,RR
Old 08-06-2013, 07:53 AM
Dadddio's Avatar
It works by forcing the fluid up from the slave/calipers rather than down from the master.
Since air wants to rise, it is much easier to purge the bubbles this way.
So I've read.
I've never done this, just wondering.
Clutch just doesn't feel right.
Old 08-06-2013, 09:03 AM
harborman's Avatar
I never heard of it myself. I always bleed from the Master Cyl and never had a problem. In fact I just use the self bleed kit with bottle you attach to bleed screw and it works just fine. I use that Super Blue fluid, so when you see the color change, you know you have changed the fluid in the lines.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 08-06-2013, 11:30 AM
Kool
AirtekHVAC's Avatar
I was considering doing it myself, there is quite a bit on the web about it.....
Old 08-06-2013, 01:49 PM
Pete R's Avatar
but you have to force it down into a large chamber in the brakes with the bleeder on the top. I don't see it working on the brakes. maybe the clutch
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 08-06-2013, 03:58 PM
rjm65's Avatar
My concern would be that you first flush the brake system normally so you aren't pushing any contaminants up into your master cylinder when you reverse bleed.
I've reverse bled the clutch slave by using the LF caliper as my pressure bleeder, just ran a small hose from the caliper bleed screw to the clutch slave bleed, worked like a charm.
Raymond
1979 928 5 spd
Old 08-07-2013, 01:36 AM
I found the clutch a nightmare to bleed. Finally got it working by gently pulling the MC piston, just, ant letting the air out there. I tried all other methods known to man, without any progress.
Old 08-07-2013, 03:16 AM
MPDano's Avatar
Funny, I actually did this for the first time last week on my Of Road Buggy. For some reason traditional bleeding wouldn't work. You get a large syringe full of brake fluid and force it through the calipers, forcing air and fluid out the MC.
I would do the traditional bleeding method first as we all know this works on our 928's.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-07-2013, 05:28 AM
