Finding parts
Hi Guys
Im looking for the protective plate that comes under the engine, no Porsche parts site has them, anyone knows a junk yard \ shop that sell used parts?
THANKS
Old 08-08-2013, 09:48 AM
stepson's Avatar
What year is your car?
Are you talking about a belly pan? '87 and up are the only models that had a true belly pan. The earlier cars just had a splash guard to protect the front of the engine, more or less.
Aftermarket Aluminum Belly pans are available from 928Intl.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 08-08-2013, 03:15 PM
curtisr
curtisr's Avatar
Hmm, that might explain why the belly pan on my '82 only had a couple of screws holding it in place (and a cable tie or two if memory serves).
Old 08-08-2013, 04:50 PM
928: Serial Enabler
There are several different versions of the earlier thin aluminum underside cover.
Old 08-08-2013, 04:52 PM
stepson's Avatar
But IIRC, they were all just versions of the same thing that extended from the bottom of the radiator to mid-alternator area. They basically protected the fan and belts from road debris from entering that area.
Whereas the true belly pan is a louvered flat plastic (originally) 2 piece (front belly pan and rear belly pan) affair that protected the whole underside of the engine/steering rack/bell housing area and extended back approximately 5 feet combined under the car. The original rear belly pan was aluminum that connected to the plastic front probably due to it's proximity to the exhaust heat. A lot of cars have no belly pans at all since they had to be removed to even change the oil and mechanics would forget (tongue in cheek) to reinstall them. They do provide much more protection than the earlier covers and added additional aerodynamic benefits.
The aftermarket aluminum belly pans that 928Intl sells are the front belly pans designed to fit on the '87 and up cars.
Old 08-08-2013, 10:38 PM
928: Serial Enabler
Agreed. 87 up is a whole different deal.
The 85/6 pan has a different bump-out to accomodate the larger diam alternator.
It probably will still fit on earlier car. (reading op other posts, his is 84 car?)
They were a PITA so I took them off all mine.
I'd offer one, but I gave Jim Doerr the better ones for use on #6 and his silver 78, and the rest in this stack on the floor are bent a bit..
Old 08-09-2013, 12:45 AM
sorry guys MY 928 is 1984
anyone ?
Old 08-09-2013, 07:16 AM
928Intl dont have the protective plate :-(
Old 08-09-2013, 11:05 AM
I got mine, new, from 928srus a couple of years ago. Roger commented at that time that it may have been the last new OB belly pan in all of Porschedom....so, finding a new one may not happen...and I have never seen a used one for sale. It was evidently the first thing removed and scrapped from a 928. There has been a lot of discussion regarding overheating might be caused (or not) by the belly pans on later model cars. What I notice on my '84 is the front of the engine stays cleaner, less sand, than when I was running it without....
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 08-09-2013, 03:30 PM
curtisr
curtisr's Avatar
928 Motorsports offers a replacement engine belly pan. You can get it at: 928 Motorsports LLC® - Performance Parts - Engine Belly Pan for the 1987-95 Porsche® 928 S4, GT, GTS - Porsche® 928 World record Holder 216.63537 mph
I'd call any of the dismantlers. There's plenty around including: Partsheaven New, Used, Rebuilt Porsche Parts
Old 08-09-2013, 08:29 PM
Network Native
Danglerb's Avatar
Early pan is very fragile, and much searched for by new buyers, but most give up or fabricate something.
Old 08-10-2013, 01:36 PM
Kool
AirtekHVAC's Avatar
How hard would it be to make one? I might do that one of these years....
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 08-10-2013, 03:24 PM
Network Native
Danglerb's Avatar
The factory part is all curves etc, not easy I would think to duplicate, but a functional pan I don't think would be that hard to do with straight bends.
I have a factory pan I bought somehow for one of my cars and no plans on selling, but I might get a chance in the next couple months to take some pictures.
I'm thinking about making a much heavier plate in like 16G aluminum that would also act as a cross brace between the front chassis "arms", like a Baja plate on a truck.
Old 08-20-2013, 01:02 PM
Kool
AirtekHVAC's Avatar
I used to have access to a full metal fab shop before my recent "fall from grace" and would think it would be quite easy with the right equipment....perhaps diamond plate? That would be neat....
Ron
Old 08-20-2013, 04:33 PM
Network Native
Danglerb's Avatar
That was my plan the diamond plate I found in sheets in a couple metal surplus places fairly cheap. I'm thinking with a couple bends it will be stiff enough to act as a brace to inward motion as well as outward between the two sides of the front frame.
Old 08-21-2013, 12:09 AM
Engineer of profanity
924CarreraGTP's Avatar
I posted this before. When I still had my '83 I thought about using the original part from my '84, cutting a piece of hard plastic, trimming to size, and then melting it to my '84 belly pan with some oil between using a blow torch. Then separating the plastic from the original piece and in essence you have a carbon (plastic) copy of the original belly pan. I traded my '83 though and never got it.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 08-21-2013, 04:02 AM
Kool
AirtekHVAC's Avatar
Makes perfect sense to me... :/
Ron
Old 08-21-2013, 04:19 PM
