laneyamps's Avatar
Climate Control Module Question
Has anyone ever taken one of these apart?
Assuming "dirty contacts" on the upper slider (DEF, VENT, FLOOR, A/C, HEAT) I have to jiggle it to get the a/c to stay on. A/C works awesome (ice cold)...I just have to play with the slider mechanism to get the A/C to stay on.
Just wondering if anyone else ever took one of these modules apart?
Easy job???
I'll take it apart next weekend, anyway. Just curious if anyone ever cleaned the contacts on the sliders
Thanks, y'all
84' 928S Black/Black
Old 09-07-2013, 12:12 PM
Petie3rd
Mrmerlin's Avatar
I have taken them apart all the time,
usually to replace the relay for the AC.
link with pictures
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CEYQFjAA&url=http%3A%2F%2Fforums.rennlist.com%2Frennforums% 2F928-forum%2F497585-ac-hvac-relay-replacement-with-pics.html&ei=G4ArUs_LLvHUyQGH34GYBA&usg=AFQjCNHL0sQwinlkanjLLBLMugtYKW6Ehw&bvm=bv.51773540,d.aWc&cad=rja
Old 09-07-2013, 12:35 PM
laneyamps's Avatar
[QUOTE=Mrmerlin;7643940]I have taken them apart all the time,
link with pictures
Hey Merlin,
Thanks.....I'll tackle it next weekend!
Old 09-07-2013, 06:45 PM
Petie3rd
Mrmerlin's Avatar
Your welcome Laney
Old 09-07-2013, 08:19 PM
928-Electrics Guy
Alan in AZ's Avatar
Thanks, y'all
You seem a bit confused... the upper slider is temperature not vent position. The lower slider is not the primary means to get AC on - the AC switch located on the panel below is. While the head switch can command the AC to come on - if the AC switch is turned on it will ensure it stays on all the time.
Maybe your main AC switch is unplugged? You may need to clean the head unit wipers & tracks to get those to work right - but AC should work even without that.
Alan
1994 928 GTS Black/Black Manual
Old 09-08-2013, 06:43 PM
laneyamps's Avatar
Alan
Thanks Alan,
You're right...sorry...I failed to explain properly.
Lower slider.....And yes, the A/C Button (on the RH Side) works perfect, but, the slider gets quirky. I have to jiggle the lower slider (in between positions) to get the a/c to "catch". I'll take it all apart, clean up all the contacts, and sliders, and I'll keep you guys posted after I have it all cleaned up. Probably not a big deal.
Thanks for the reply!
Chris
Old 09-10-2013, 09:27 AM
928-Electrics Guy
Alan in AZ's Avatar
AC button should be on the left...
Point is that when that switch is on - you should get the AC clutch on regardless of the slider connections (except for the off position).
It may be good to clean those sliders - but you must have another different problem to have the behaviour you describe - perhaps a loose connector (switch or head unit) or other issues.
Alan
Old 09-10-2013, 10:08 AM
