curtisr
Starts. Stops. Sigh...
Hi,
Hoping someone can help me with my 928's starting and quitting issue. It seems that it will fire reliably with a mere turn of the key (as it always had) but it quits right away. So far I've:
Other info:
Thanking posters in advance. Roger |
It would help if you give the year of the car so we know what ignition/fuel system we are dealing with.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Petie3rd
at the top of the page click on user CP
then find edit signature , then add your year and model of 928, and trans type, and any other mods you have
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
SharkHead
...and after you give specific's on the MY...describe the observations...when cold or when warmed up...dies within 3 seconds after starting...does not restart after stoping...
'79 928, 85k Opal Metallic '99 BMW 540i, 97k Titanium '72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga |
curtisr
Must have been too frustrated with recent efforts and lack of success to think clearly. This should be better.
My '82 ROW 928 has an A/T and (presumably) an L-Jetronic Bosch FI system. About a month ago I was trying a new seat switch when my troubles began. I inserted the new part, tried it and was immediately greeted with smoke. Prior to that it started and ran without a hitch. When I tried to start the car right afterwards it would start right away and then run for a second or two before quitting. The car was cold. So far I've:
Other info:
I love this car but hardly seem to ever be able to drive it as it's one thing after another. So, any suggestions are more than welcome and greatly appreciated.
Petie3rd
then find edit signature , then add your year and model of 928, and trans type, and any other mods you have Once this is done then the info will be on every post you make, Thanks Maybe this will get your attention
Looks like that 928 had an ejaculation judging from the wetness. What a great pic.
Mark 1981 928 |
Finally a hot woman standing over a hot car. What Merlin says, put that info in your signature.
FYI on your 82 Euro Specs: 80-82 - 3-auto (Euro) 4.5L-16v M28/10 229 271 10.0:1 K-Jetronic 140 7.7 16 3197 S Version which you can prove with the numbers on the front of your engine: 80-83 S - 3-auto (Euro) 4.7L-16v M28/12 300 263 10.0:1 K-Jetronic 152 7.2 15.5 3197 Both CIS. Post pics of your engine. Here is where to find the engine numbers: ![]()
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
curtisr
Wilco.
Petie3rd
curtisr
![]() Still hoping some suggestions might come my way.
Roger,
It is not likely that you will get suggestions until you post specifics about your car. MrMerlin has asked you to post your information in your signature. MPDano has given you a picture showing with an arrow and a closeup where your engine model number is located. You have stated that your car is a ROW and has L-Jet, yet ROW(Euro) for that year is clearly K-Jet as MPDano has indicated. The engine model number is necessary to know. Your further response was a generic picture of an intake without much detail. We would all be willing to help, but you're gonna have to help us help you.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Petie3rd
M28/14 =1980 928 US 3 speed auto, 4.5L, 220HP, 265 FT/TQ , 9.0:1, L jetronic, top speed 140mph, 0-62 8.5sec.,1/4mile 16 sec., wt 3385 lbs
curtisr
Found it! Now how did I miss that? Anyway, it's an M28/16 (81-82 - 3-auto (ROW) 4.5L-16v M28/16 220 265 9.0:1 L-Jetronic 140 8.5 16 3385--Thanks, Leo
Yea! One small step for man and a giant leap for mankind.
curtisr
1977 924 Guards Red (parted and sold) 1987 924s Alpine White (sold) 1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold) 1987 924s Garnet Red (currently becoming Lowencash II) 1982 928 Silver (sold)
Petie3rd
Thanks for updating your signature.
The info about the M28/16 engine you posted is correct except for one part, its a US engine not a ROW . For 1982 ROW or Euro it could be one of 4 engine codes M28/9, M28/10,M28/11,M28/12. Note M28/11, M28/12 are 300HP engines. M28/9, M28/10 are 229HP. For your running issue I would suggest to disconnect the battery and drop the CE panel. So you can inspect all of the wires on the back, you will be looking for wires with shine to them, you will note that the wires that have not gotten heated will have a satin finish in the insulation, the wires that have seen heat will be shiny. Look for wires that may have melted into the others as they cross. Please Take pictures of the CE panel and post them before you do anything. Also inspect the fuel pump fuse wires where they plug into the rear of the panel, with the battery connected make sure that both wires have 12V going into the wires, its common for the fuse to test good but the pin connectors get corroded on the back of the CE panel, and thus the fuse is good but the wire isnt getting power. Also check the harness that you let the smoke out of. You didnt say what seat you were working on , BUT there is a harness that will have melted wires, you only need ground and 12v to the seat to run it, trick is to find out what wires in the seat are for what
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 09-11-2013 at 05:23 PM.. |
curtisr
Thank you, thank you, Mr. M. I stand corrected on the ROW/US notation. Will correct.
I will set aside the weekend in order to re-visit the fuse panel. When I first considered a 928 my homework said: 'clean every ground, fuse panel connection--rinse, repeat' and electrical problems are often fixed by keeping the 'relay, relay, relay' mantra in mind. And to date I have checked each fuse for voltage, found some with 3.7 v and cleaned these, changed the grounds supply (as it were) for a number of connectons, pulled the fuse panel for additional checking as required. For my current problem I have replaced the fuel pump and the fuel injection relays. Given that it ran the other day when it was rather hot here I guess I have to revisit the fuse panel. The seat was the passenger side front. The switch was the up/down adjustment. The seat still tilts and goes back and forth with the existing switches. I have yet to take a look at the motor to see what kind of condition it is in. Regardless, I will replace it with a spare that I have. I look forward to the weekend when I can revisit the CE. Thank you again.
Network Native
18 posts and nobody has said Green Wire yet?
Usually the switches fail on seats, windows, sunroof. Grease gets old and gummy on a lot of bits, seats, sunroof, etc. |
Petie3rd
Dan, from the first post the car was running fine till the OP let the smoke out of the wires while installing a new Passenger seat switch
