1980 Porsche 928
Exhaust failure, 1980.
I had just got my new borla exhaust system up and it was sounding good, smoking kinda bad at times. But it was at about 2000 RPMs. And it just sputtered and died with a popping noise and shut off. Waited a bit. It fired and ran and died in like 5 seconds. The dash says OSX, maybe an O2 sensor failure? Any ideas
Old 09-29-2013, 07:26 AM
harborman's Avatar
Sounds like something along those lines. If it ran fine before your new exhaust and this is all you did, then something changed for sure.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 09-29-2013, 08:51 AM
1980 Porsche 928
Yeah it ran pretty well before hand. It didn't really have anything past the cat, and now this new borla. It doesn't stay running for more than 5 seconds
Old 09-29-2013, 09:00 AM
1980 Porsche 928
Do you guys have any ideas of what it could be?
Old 09-29-2013, 02:58 PM
MPDano's Avatar
What condition is the cat in? Could be plugged?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-29-2013, 04:09 PM
1980 Porsche 928
Cat is original. Pretty rusted on the outside.
Old 09-29-2013, 04:21 PM
MPDano's Avatar
Remove it and then start it. If it lasts more than 5 seconds, than there is your issue. If your not required in your state, then put a straight pipe and clamps in it's place.
Old 09-29-2013, 06:16 PM
Network Native
Danglerb's Avatar
When you changed the exhaust did you mess with the O2 sensor, maybe unplug it? OSX means a problem with the O2 sensor unless it going out once you tap the gas a little.
Gas in the tank?
Fuel pump running?
What color was the smoke?
Old 09-30-2013, 05:41 AM
harborman's Avatar
I guess my point was that when work is done, sometimes other things are disturbed, like the O2 and wiring. Seems the guys are pointing you in the correct direction. Let us know how it turns out.
1986 928S
32 valve engine
Old 09-30-2013, 08:43 AM
1980 Porsche 928
I did not do anything to the O2 sensor. Smoke was black at first, probably burning off some of the nasty stuff in the engine, turned clear later. Perhaps something happened to the O2 sensor due to all the new back pressure because it did not have any exhaust except the cat a first. Will a bad O2 sensor stop the car from running?
Old 09-30-2013, 03:31 PM
1980 Porsche 928
Okay started up today without any problems. I did nothing, took off the back half of the new exhaust system though.
Old 09-30-2013, 03:35 PM
1980 Porsche 928
Okay it shut off again, still saying OXS. Doesn't seem to run at all now.
Old 09-30-2013, 03:44 PM
Fixer's Avatar
Sounds like what my '83 did when the alarm acted up due to removal of just about everything inside the car.
Had to bypass it and it fired right up. Check glove box, door light switches..
Doesn't sound like something your exhaust would cause.
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 09-30-2013, 04:11 PM
Just for laughs, to rule out the o2 sensor, have you tried putting the car in open loop mode by unplugging the wire at the passenger footwell?
My Car:
84' 928 S with Euro Mods - Quartz Gray Metallic (Quite the project!)
Old 10-01-2013, 09:23 AM
1980 Porsche 928
Which wire to be exact?
Old 10-01-2013, 01:11 PM
something like this (green wire with connector), color may vary from year to year. but it feeds down the same spot
My Car:
Old 10-01-2013, 02:11 PM
1980 Porsche 928
That did not fix it, still says OXS. Just sits there and grumbles, not wanting to stay running. Could it be the ignition box?
Old 10-01-2013, 03:11 PM
1980 Porsche 928
I'm ya a loss right now. Taking off the cat right now, you really think that could be it
Old 10-02-2013, 04:23 PM
1980 Porsche 928
Okay so I started cranking the engine and it started firing barely and I held the gas petal down and I was still holding the key over to keep it going(probably not very good on the starter) but once it finally got to 1000rpms the OXS shut off. And it puts out tons of exhaust. Is there any possibility it could be a bad ignition coil? I believe it to be the original one, and I have replaced everything else in the ignition system besides the coil and the computer.
Old 10-02-2013, 05:18 PM
harborman's Avatar
When a 928 floods out, it floods out but good. Not sure about your problem but after I replaced my fuel lines it would not start. Plugs were all wet. Finally I just put the peddle to the floor, kept cranking and it started with a big cloud of smoke.
1986 928S
32 valve engine
Old 10-03-2013, 05:21 AM
