DZGunner's Avatar
Fuel tank
How do you know if you have the in tank pump or the in tank filter screen?
If you need pictures from the outside to tell i can provide them
1987 928 S4 - Guards Red
Old 11-11-2013, 05:06 PM
Kool
AirtekHVAC's Avatar
Wires will run to the fuel outlet at the tank if you have the in tank pump.
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 11-11-2013, 05:36 PM
DZGunner's Avatar
ok thank you
Old 11-11-2013, 06:51 PM
stepson's Avatar
The extra wires will still be even if you don't have an in-tank pump, but they will be taped off and not connected to anything.
Go ahead and post the picture just for grins. It might help somebody else down the road.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 11-12-2013, 11:35 AM
Should you swap from one type to the other, be aware that the hose size from the in tank pump is a different diameter to the internal filter only type.
(I got caught on this one, dumped the in tank pump, ordered an in tank filter, got it in, then had to wait another 2 weeks for the correct hose to arrive.)
'82 928,2002 4.3 lexus quad cam VVTI V8,5 spd Auto.(at the front)BorgWarner 3.08/1 LSD-at the back-Weisach retained,Transaxle gone.Borla exhaust,XSchops Cayenne big brakes front ,968 front brakes rear.Mk4Supra m/s & servo. Alloy rad,1380kgs(3036 lbs(53%F/47%R))
Old 11-12-2013, 12:51 PM
stepson's Avatar
Yes, the in-tank filter only fitting is half again larger than the in-tank pump fitting and consequently the hose is larger as well. I have replaced the in-tank pump on my '89 and I have replaced the in-tank pump on my GTS with just the filter and new hose. I really cannot tell any difference in performance without the in-tank pump on the GTS, and I have had no vapor lock issues whatever.
Old 11-13-2013, 10:25 AM
