Anyone Have Source for Exhaust X-Pipe for 16V Engine?
For M12 engine, 4.7 litre 16V, I need from the headers back - no CATS, No air pipe, no OX sensor.
OTT has the exact needed design, but only for 32V systems, seen here- http://www.performance928.com/images...es/ci_0492.jpg I can't find similar for 16V engine. I have found an H-Pipe, but I don't want to use an H http://c767170.r70.cf2.rackcdn.com/RBA7908.jpg Any help would be appreciated. |
I used MSDS long headers and had an X built post headers
uBoat, you might go check out Rennlist.com. there are many more fabricators over there that might have a solution for you.
Roger I think sells the Dave Lomas X, but I don't know fitment details relative to the 16v. The common setup is to use a set of US 85/86 exhaust manifold on an early motor and that requires a small adapter on one side.
Its some serious money, but I am thinking I will go with a full Greg Brown exhaust, makes more power and torque than anybody else and has a H at the front and X at the rear. |
Sorry - not a long-time member here. Seen it said 20 times, "Roger has this, Roger has that..."
Who the heck is Roger? |
Roger at Home - 928s R Us Porsche Parts Store
As soon as you say "It's some serious money.." you already know I am out ;) |
You want a Y pipe, not the X. Last I heard Roger does sell them.
In the pursuit of going fast, there is a very limited amount of gain that comes cheap, and at several points all the options are kinda pricey to get to the next level.
Question I ask is it expensive, or Porsche expensive. If you are at say 320 rwhp, and you have a strong itch for a "little" more power, there isn't anything cheap left to do, maybe nitrous, but that makes a drag car out of a 928 more than anything. Greg likes to make torque, and on a strong motor, a Euro hybrid, or a 32v or a stroker, his exhaust system has the best gain in torque and rwhp that at a couple grand nothing else will give the same gain/$. His design is a bit different, but it seems to work. |
Try Summit Racing.com You can buy a close coupled X pipe, and a muffler shop can connect your existing pipes to it. Parts and labor should be much under $150.
-KK |
Jim Bailey has a used setup for sale at a very good price over on the "other" forum.
I was unable to find anyone that had a complete downpipe to tailpipe solution with an x-pipe for a 16V.
I did find this with an H, fully stainless, with rear resonator, for $1400 new http://forums.pelicanparts.com/uploa...1386642264.jpg |
I made my exhaust for $50 and it runs excellent. Installing '85-'86 manifolds soon, ordered tem from Mark A. Can't wait to get them. |
Crossover Pipe, X-Pipe, Stainless Steel, Natural, 2.25 in. Diameter, Universal, Each Part Number: MPE-10790 for 2.25" Part Number: MPE-10791 for 2.5" |
| All times are GMT -8. The time now is 07:00 PM. |
