Yellowb1rd's Avatar
86 fuse panel diagram....
Pelicans,
Can Anyone tell me which connectors (A-W) control ignition and fuel injection? The car won't start and I suspect it is corroded connector, but I'm not sure which one controls ignition and fuel injection. Here is a picture of the fuse layout, with the connectors marked at the bottom. I know the location of all the ignition and fuel injection relays (which have been checked already). Assistance would be appreciated.
Old 12-08-2013, 03:14 PM
Yellowb1rd's Avatar
Old 12-08-2013, 03:15 PM
Porsche 928 Fanatic!
https://www.928gt.com/t-8586fuse.aspx
Webmaster - www.GreatWhite928.com
250+ 928s for sale at all times!
Old 12-08-2013, 06:52 PM
928: Serial Enabler
Primarily U and W.
You really need the wiring diagrams so you can self-answer such questions.
84,85,86 928 cars
Old 12-08-2013, 10:47 PM
Petie3rd
Mrmerlin's Avatar
FWIW there is a possibility that one or more of the individual wires may have pushed out of its connector housing.
look carefully also make sure the relays and fuses are in the correct slots
Old 12-09-2013, 03:34 AM
928: Serial Enabler
And inspect back of panel for melts. And the grounds at base of valley that are part and parcel of the operation of the electronics and can lead to one relay not triggering.
84,85,86 928 cars
Old 12-09-2013, 03:43 AM
Yellowb1rd's Avatar
Thanks, fellas! I'll check the connectors for U and W for starters, and go from there.
Old 12-09-2013, 10:28 PM
Network Native
Danglerb's Avatar
Reseating everything is a good idea, reseating with cleaning and some kind of contact goop even better.
Old 12-10-2013, 12:47 AM
Yellowb1rd's Avatar
FYI.... After removing, cleaning, and re-seating connector W, the car fired right up. Thanks guys!!!!
Old 12-24-2013, 02:20 PM
