1990 S4 Stalling problem, please help!!!!
Hi there
I recently removed the cats on my 1990 928 S4 and replaced then with bypass pipes.
The cats on my Porsche had just about had it, but I can not afford an x pipe replacement at the moment. Since then when the car gets up to operating temperature it suddenly cuts out. I changed the O2 sensor when I removed the exhaust so I assume it is not that. I have cleaned every connection I could find around the engine, MAF sensor connector, TPS etc.
Could anyone please tell me what else I should be checking. I don't know if it is simply coincidence that this problem is occuring since I did the exhaust. What would cause the car to cut out / stall when at idle? It only does it when the engine temperature starts to rise. Any help would be most appreciated.
Regards
Simon
Old 12-29-2013, 07:20 AM
curtisr
curtisr's Avatar
I assume that the O2 sensor light is not coming on...
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 12-29-2013, 06:44 PM
Porsche 928 Fanatic!
Unplug O2 sensor & run. It will run rich, but see if it continues to cut out. If it does not, faulty o2 sensor.
Webmaster - www.GreatWhite928.com
250+ 928s for sale at all times!
Old 12-29-2013, 07:07 PM
Thanks for the replies guys.
The O2 sensor light is on. I will try unplugging the sensor connector to see if the car still stalls and let you know how I get on. If this does not cure the problem is there anything else I should be looking at?
Thanks once more for your help.
Old 12-30-2013, 10:30 AM
Unplugged the O2 sensor and the car did not stall even when up to temperature! The new O2 sensor I installed was the correct Bosch sensor for the car. Has anyone else ever had a new O2 sensor that was faulty from new? How could I check this?
If the new sensor is ok would this mean that the LH ECU is not working correctly? I would be grateful for any help as I am at a loss of what to do next! Many thanks for the help so far.
Simon
Old 01-02-2014, 09:48 AM
Simon
I had a faulty brand-new Bosche O2 sensor, that is why I suggested you try this - glad it was that simple
Old 01-02-2014, 09:52 AM
Thanks for the quick reply
I suppose all I can do is get another O2 sensor any try again. I am hoping this will sort it out as I know the LH ecu's can be quite costly to repair / replace if that was the problem!
Old 01-02-2014, 10:12 AM
