Just a couple questions
So I've been driving my 928 for a couple months now and i finally have some time to fix a few of the issues I have. I went through and replaced the timing belt and the engine looks and seems to run pretty good. I`ll just list some of the things ive noticed while driving it.
-It does idle high when I'm in neutral, but once I'm in in drive it idles perfect. Other than being really shaky. -The power steering whines a lot and very loudly, I filled it up with new fluid and replaced the belt but those did not help. -I'm not sure if this is just the cold weather, but it warms up very slowly. I believe its because the radiator fan is always on but i could be wrong. I`d leave it running for 15-20 minutes before leaving in the mornings and it would barely warm up at all. -I've noticed that when it does warm up it runs a lot better but it feels like there are some performance issues. On takeoff it likes to go really slowly even with my foot to the floor then it suddenly picks up and goes. -When i do try and give it a little gas trying to pick up speed or go up a steep hill it shakes really bad, and barely gets any faster. -It still shifts pretty hard too, even after filling it with more transmission fluid and replacing the filter. Also it doesn't shift until i let off the gas unless it hits 4-5000 rpm. -My windows, front wipers, sunroof, and brake lights don't always work. They used to work all the time but not rarely ever do. I'm getting 14-14.5 volts at the battery but if it sits for more than a day without being driven the battery is dead. -My sunroof when its working will turn and open by hand but the little rubber piece that connects the motor to what turns to open it is ripped and I'm not sure how to find a new one or fix it some other way. -lastly the rear wheel bearing needs to be replaced, I already have the parts i just need to know if there's anything different from any other car to look for or do when i change it. If anyone can help me fix these problems that`d be great. Thanks for taking the time to read this. Oh and i forgot to mention the car is an `85 auto and I'm located in West Des Moines Iowa |
SharkHead
Something is not right. I am not that up on your MY. But timing sounds like an issue or vacuumn maybe fuel. You also have less significant issues to deal with.
Someone may jump in with a little guidance. Check your timing, vacuum lines, fuel distribution, compression. You indicate a timing belt refresh; if these engine behaviors happened after that check your cam configurations first. Hopefully a configuration issue and not a failure in the valve train. I hope you are a gearhead
'79 928, 85k Opal Metallic '99 BMW 540i, 97k Titanium '72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga |
Good Luck
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Network Native
Ouch, 911 624 103 00 the sunroof "clutch" is Porsche only part about $130. Pelican has them, but price seems nuts to me, I would be looking at alternatives. Used is a first thought, but, used 30 year old rubber doesn't seem too smart.
Thanks all for the help. Ill get to work looking at it and ill hopefully get everything done smoothly. If i need anymore help ill definitely be back to ask. I did notice one thing, most of the suggestions to fix my problems were through vacuum leaks. So is there a point that they are connected that would cause all these problems or is it just multiple leaks? Again thankx for the help i really appreciate it.
Joey,
There should be a diagram of your vacuum system on the decal on the underside of your hood. As you can tell from that diagram, it is a complex and far-ranging system and leaks can occur anywhere. Check over by the brake booster. There is a small vacuum line leading to a blue one-way valve. Check the operation of that one-way valve. That can cure a lot of ills of accessory-type stuff. Engine vacuum leak stuff is more typically MAF boot and large vacuum lines split/cracked/unplugged.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) Last edited by stepson; 03-15-2014 at 10:33 PM.. |
Network Native
One of the reasons vacuum leaks get suggested so often, besides matching symptoms, is that there are so many places for small leaks to occur. Best to replace all the old hard rubber with new.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
MP Dano you think that bucking and shaking could be TPS sensor placement on the throttle body?
Put your model year in your signature so it will be a lot easier to troubleshoot. Lot's of changes throughout the years. Vac leaks is what I would sort first. Full intake refresh with fresh silicone or rubber first. Since I don't even know what year your car is, it may not even have a TPS.
Recovering dismantler
Leo, in first post " 85 auto" and it does have a TPS.
Hobbyshark: WSM vol 1A page 24-115 for TPS check procedure. Check the Temp II sensor as well, that could very well be causing your problems. WSM 1A page 24-114. Neil
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
Neil knows the 85 well as he has one. I'm not really up on all the sensors they have.
Thanks for all the replies so far. They have really helped me out in getting this project underway. I was thinking earlier that it would probably be easier and best for me to just go through and replace all the vacuum lines, as Danglerb mentioned. I just need to know how much of what size hose is needed. Also if ill need any new connectors or if the old ones will work fine.
1985 auto |
Network Native
Roger has a preassembled kit, highly recommended. Home - 928s R Us Porsche Parts Store he uses MB couplings and good quality hard nylon tubes.
Roger's kit includes the necessary vacuum junctions, but is not preassembled. You have to cut the hose yourself and route it.
Scott '86.5 928S (Guards Red/Black/5 speed/Stock tensioner) California car '87 928S4 (Grand Prix White/Black/5 speed/PorKensioner) Daily driver '99 996 (Black/Grey/6 speed) Wife's car '12 Honda Civic Si (Black/Black/6 speed) Wife's daily driver |
Network Native
928-Electrics Guy
From the described conditions I'd be wondering if its only running on one coil... or at least missing some cylinders - any gas smell in the exhaust?, any holes/plugs really wet?
Electrical issues sound most likely to be the ignition switch. Test CE pin F21* with the accessory/ignition on - any power there - does it vary when you wiggle the switch? any difference between accessory position and ignition position? *Plug F - the bottom connector on the right side column. (BTW - this is for an '85 NOT all years) Alan
1994 928 GTS Black/Black Manual |
there is difference when i have just the car on everything works, but once i start the engine it doesnt work anymore. I was thinking to check in the ignition if cleaning all the grounds and the rest of the connections didnt help.
1985 auto |
