Abs delete
Ok so after much thought blood sweat and cursing I decided to completely delete the abs system. It is way to far out of my budget to repair it would need a complete overhaul. So I am asking for help in rerouting the lines to the master cylinder. Can I use an 83 master cylinder pre-abs? Or can I use my existing master and reroute my lines? Does anyone have just a schematic of the brake lines? Thanx all
928: Serial Enabler
Just drive it. Why re-route? Those things are designed to operate even if electrics fail.
84,85,86 928 cars |
The brakes on a 928 are among the best put on a car year to year. Why not just fix it correctly? We can help diagnose your issues.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Recovering dismantler
Do as Chris says, just pull the fuse on the ABS - then you have no ABS.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
It's a little late for that I had to cut the lines to the abs unit in order to remove it. It is now out. Is there a tool to reflange the lines or do they have to be replaced?
And BTW the passenger front caliper was replaced, the braided flex lines were replaced and it still would not shoot fluid out
Mind you I did pull the fuse first and I still had no rotor grip on the front passenger. It was definitely an internal abs solenoid issue
For all who may be interested I successfully deleted abs from the car as I never liked abs for the most part and tend to feel for the cars breaking point in traction minus rainy situations. The abs brake control unit had 5 lines in.... Two that go to the master, one for each front wheel and one line to the rear. I rerouted the three lines to the wheels to go to the master with only two inputs to the master I made a tee coupling then cut and reflanged all the lines.
928: Serial Enabler
Sounds like a redneck approach. Hope you do better with the rest of the car. Tell us you at least used double flares.
84,85,86 928 cars |
Network Native
Isn't there a proportioning valve in there someplace? Front and rear need different pressure don't they?
'82 928,2002 4.3 lexus quad cam VVTI V8,5 spd Auto.(at the front)BorgWarner 3.08/1 LSD-at the back-Weisach retained,Transaxle gone.Borla exhaust,XSchops Cayenne big brakes front ,968 front brakes rear.Mk4Supra m/s & servo. Alloy rad,1380kgs(3036 lbs(53%F/47%R))
Redneck? Yes I am with a sprinkle of Italian, I live in the south so when in Rome...lol yes 928's are bubble flares but when hooking up to a tee for the front you have slim pickings and must adapt accordingly. A proportioning valve should not be needed as it has a basic one from factory and also the wider wheels in the rear staggered fitment need that more grip to begin the deceleration process.
A Wrench
Continually amazed by what I read here. Please tell me this car is going to be used on a closed course track and not on the streets. What you have done here is put the brake bias at 50%, which is a **** ton more than it should be and in any emergency situation you have a high chance of losing control of the car.
'88 Supercharged and lots of other fun stuff. |
