77tony's Avatar
1979 Pod wiring
Anyone know where the two white wires on left go ? They are under the left side of pod of 1979. TIA.77tony
Old 09-04-2014, 10:04 AM
Hold On's Avatar
Look like the center console and pod light rheostat wires. Attach to the round rheostat dial under pod just to left of steering wheel.
Old 09-04-2014, 01:09 PM
77tony's Avatar
Hey Kev, Isn't the 2 blue & 2 black wires the dimmer rheostat and the two white wires are ? T
Old 09-04-2014, 01:22 PM
Pete R's Avatar
The other two I think are the high pressure wash for the front headlights
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 09-04-2014, 02:00 PM
77tony's Avatar
Doesn't appear they will reach under the pod on the right side ? T
Old 09-04-2014, 02:13 PM
stepson's Avatar
T,
It doesn't make sense that Porsche would make both wires the same color from the factory. Methinks that the wires were replaced in a previous life. Try to find what color those wires connect to in the harness. That would make it snap to find what they are supposed to connect to.
Not to say that any of the previous answers are incorrect, but knowledge is power.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
77tony's Avatar
Originally Posted by stepson View Post
T,
Thanks John. Will dig a little deeper. See you at 3rd Coast ? T
Old 09-04-2014, 02:26 PM
Hold On's Avatar
I have the pod out of mine. The only two wire groups I have right there are light rheostat and the button for the high intensity windshield washer pump. I will look when i get home and let you know which is which. K
Old 09-04-2014, 02:53 PM
Hold On's Avatar
On my wire diagrams it shows the BK/Bl and BK wires for the intensive washer. Your picture shows those wires. The light rheostat is just a variable resister wheel so it has the same color wire coming out as going in. Mine is white. BTW gauge/console lights will not work at all without the rheostat in place.
Old 09-04-2014, 03:19 PM
77tony's Avatar
Got it. Thanks guys. T
Old 09-04-2014, 04:40 PM
stepson's Avatar
That is really strange that Porsche would do that
But all you have to do is jumper the two wires together and it would be full bright all the time
Yes Tony. I will definitely be at Third Coast with Rhonda
Old 09-04-2014, 04:55 PM
Hold On's Avatar
That would be obvious....
Tony, Ignore the man behind the curtain... My 83 is set up different. Bk & Bl wires on left side of pod are going to light rheostat. I do have white ( maybe faded yellow) going to intensive washer button ,but they are on the right side of pod, next to the wiper delay rheostat.
Old 09-04-2014, 05:30 PM
I forget the colors on mine but I remember the the Wire hook up connections and they look like your white wire connections . All you have to do is just hook up the wires together and plug in the 3 wiring hook ups to the Cluster and see if the Dash Light Bulb's work . You want all the way Bright so just leave the wires hooked up all the time . If they don't come on check the Bulbs ( Its the Large Bulb's in the Instrument cluster ) All the way Bright is not very Bright on a 928 you may want to switch to Led Bulbs.
Or You can hook up the 3 Cluster Connections then the Wires together and you should see the Lights come on ( Ignition Key ON )
Note : be very careful with the wiring hook up to the cluster or breakage well result , hook wiring on gently and don't let the cluster hang and pull on the wiring as this well damage the hook up and things well stop working > talking Gauges / Spedo
Old 09-04-2014, 06:25 PM
77tony's Avatar
Thanks again everyone. T
Old 09-04-2014, 08:23 PM
