Network Native
Danglerb's Avatar
Injector cleaning, Witch Hunter, or ?
Anybody try anyplace other than Witch Hunter?
Seems like injector cleaning is big biz these days, some nationwide chain called ASNU, plus a bunch of small shops.
Witch Hunter looks like $22/inj for clean, test, new filters and orings, plus shipping and some additional to make matched sets.
Couple places on Ebay clean and test for $80 including shipping, but no parts replaced (bone head easy, but sometimes no so easy finding right parts for 928).
Old 02-10-2014, 03:48 PM
MPDano's Avatar
Why mess with a proven shop. Go Witchhunter or go home
In all seriousness, I've used them twice (928 and my late Turbo Eclipse) and have been very happy with my results. You've seen my before and after and the printout they include. Be my guest and experiment with others, for me, when my Expedition comes time, I'm sending all 8 to Witchhunter.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-10-2014, 04:52 PM
Pete R's Avatar
Marren in Conn. Did my 951 injectors. I got printouts before and after. Quick turn. Same price. I never dealt with the other guys but I couldn't have asked for more from Marren. They found 2 bad injectors and they also had the wrong pintle caps on them. I think that's what they called them) Anyhow they changed all the seals and caps in the cost of the plan. They also sold me 2 good used ones. All were with in 1% of each other when done. I had more torque with the right spray pattern. 6 of one I guess.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 02-10-2014, 05:09 PM
Network Native
Danglerb's Avatar
WH was showing a 6 day process time last I checked. I have 8 dirty looking injectors I found in a oil pan with a little oil and three or so sets of injectors I have pulled.
Long term plan I want to update to modern injectors and rails.
Short term I figure if its worth sending them out, its worth getting a matched set, which means getting a couple more from wherever I have them buried, or also pulling the set on the car now. If I need to pull the ones off the car a shorter turn around would be good, as its getting moved daily.
I found a place in San Bernardino, Calif, but so far WH seems smart.
Old 02-10-2014, 06:24 PM
MPDano's Avatar
You do know that WH will flow match your injectors, don't you?
Here's some before and after and printout
Old 02-10-2014, 07:50 PM
syoo8's Avatar
+928 on WitchHunter. Quick turnaround. They really know what they're doing.
FWIW Greg Brown recommends that we change our injectors every 15-20 years...
Scott
'86.5 928S (Guards Red/Black/5 speed/Stock tensioner) California car
'87 928S4 (Grand Prix White/Black/5 speed/PorKensioner) Daily driver
'99 996 (Black/Grey/6 speed) Wife's car
'12 Honda Civic Si (Black/Black/6 speed) Wife's daily driver
Old 02-10-2014, 07:52 PM
stepson's Avatar
I have used Cruzin' Performance in the past and was very satisfied. Got all the printed performance data for each injector. All the filters were changed, all the injector bodies were refurbished, and new O rings were sent as well. Richard called and apologized for not being able to put the correct 928 sized O rings on the injectors because they were Ford injectors(and since they weren't meant for Porsche cars, he would have all kinds of liability issues). I asked if he would supply the correct O rings to me so I could put them on and he agreed to send them along. IIRC, they were slightly cheaper than WH, but the limiting factor for me was that WH was on vacation for 2 weeks when I was ready to send my injectors.
I would use Cruzin' Performance again
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 02-10-2014, 08:10 PM
Network Native
Danglerb's Avatar
Matching doesn't change anything about your injectors, they clean and measure the flow, nothing more. To get a matched set you need EXTRA injectors to select from. I figure a minimum of two extra to remove the worst two, so send 10 to get 8 matched and two spares. I may just send 16 if I find another full set.
OTOH just cleaning got your set of 8 within a couple percent.
You didn't or couldn't remove the hold down clamp?
Old 02-10-2014, 11:50 PM
Network Native
Danglerb's Avatar
Found this in the suby forum, very nice reference. Prices are clean/test only.
RC Enginnering based out of CA (RC Fuel Injection) $24-28/NA
Witchhunter based out of WA (WitchHunter Performance - Injector Cleaning & Flow Testing Services) $22/$10
DeatschWerks based out of OK (DeatschWerks - Fuel your Passion for Performance) $20/$5
Lesser known companies
Fuel Injector Clinic based out of FL (Fuel Injector Clinic) $20/$12.50
Cruzin Performance based out of MI (Cruzin Performance) $19/$7.50
Accurate Injector Service AIS based out of AZ (Accurate Injector Service for fuel injector service, fuel injector cleaning, high performance, calibrate injectors) $17-25/NA
Injector-Rehab based out of NJ (Injector-Rehab Fuel Injector Cleaning Services) $17/$7
Hurst Injector Service based out of MA (http://www.hurstinjectorservice.com/‎) $16.25/NA
TLF Performance Parts (TLF Performance Parts) $19/NA
Old 02-11-2014, 01:57 AM
MPDano's Avatar
Didn't know they were supposed to come apart until I got them back. Was better I kept them on, as they made them look like new
Old 02-11-2014, 04:15 AM
whatudrivin's Avatar
Being from Oklahoma I have heard of many people taking their injectors to DeatschWerks and have heard great things from them. And due to them being local it will be where I take my injectors to get them cleaned. Heard many good things from everyone in the DSM scene several years ago. But I have also heard just as many good things about WitchHunter.
\Brad/
'82 928 Automatic w/Competition Package Black/Red
Old 02-11-2014, 04:22 AM
Network Native
Danglerb's Avatar
Another place suggested to me today, LOCAL to SoCal, but I haven't checked them out for any details.
Engine Performance Injectors
12347 Penn St. Whittier, CA. 90602
Phone: (562) 693-8236 or (800) 893-2260
EPI Engine Performance Injectors. Cleaning, Testing, Rebuilding, Flowing
Called and got what sounded kind of like a answering service reading from script etc, bottom line 8 injectors is $194.57, price that high no point in proceeding.
Old 02-12-2014, 09:44 PM
MPDano's Avatar
Interesting. Now read my "local" painting thread on my Euro.
Old 02-13-2014, 04:25 AM
Network Native
Danglerb's Avatar
I hear ya Leo, Google street view isn't too kind to the location either, but a local guy said they do good work, so I do plan to check them out later today.
Seems like everybody is using the same ASNU test and cleaning rig with some variation on the chemicals etc., so I am not opposed to giving a local guy business if they offer some advantages in time or cost to make it worthwhile trying them.
Old 02-13-2014, 07:50 AM
MPDano's Avatar
Just saying that "supporting the local economy" seems to never work in my favor and has always cost me more money. My last burn was getting my KTM dirtbike cylinder re-sleeved by a local business. He effed it up to where I had to give him money to my damaged property back and still ended up having to get another jug from eBay. Never again. I will only use recommended shops from now on.
Old 02-13-2014, 08:03 AM
Network Native
Danglerb's Avatar
This one in AZ is $12 each shipped, good feedback on ebay, but not a lot of it.
Ultrasonic Fuel Injector Cleaning Service | eBay
Premium Fuel Pumps LLC
P.O. Box 8151
San Luis, AZ 85349
Old 02-14-2014, 12:39 AM
80 928
Does having them serviced qualify as "replaced"?
Old 02-14-2014, 12:18 PM
Network Native
Danglerb's Avatar
I had mine Carbon Cleaned, not cheap BTW, and its basically just running hot Techron full strength through the injectors. I am sure it does some good, but nothing like an hour in a good ultrasonic cleaner, plus replacement of the internal filter and orings is essential since a leaky oring is just as likely as a clog to be the trouble.
Oops, I see your question differently.
Nothing else except maybe the 930 used this high impedance barbed injector, so figure NEW still means made maybe 30 years ago. In use eventually the coil and other internal bits fail, but doesn't seem like that is slow deterioration, but sudden death, so as long as cleaning restores original function its a question of total service life vs DOA new units. New "maybe" has the edge, but only way to get a reliable matched set would be use for some moderate period of time followed by cleaning and testing.
That said, going to a modern four hole injector is better than any option with older single hole. Rail style fittings are safer than hoses.
Old 02-14-2014, 04:41 PM
Network Native
Danglerb's Avatar
Another shop a forum member has reported good results from.
Mr Injector - Home
Mr Injector / Bill Johnson
6280 N Government Way #4
Dalton Gardens, Idaho 83815
208-762-3450
Any gas injector cleaned for $16 plus actual shipping, ala $5 for priority mail.
Old 06-17-2014, 12:43 PM
928 Bro's Avatar
Danglerb send the extra injectors to Mr injector and see what you get back. I call it value when a vender goes the extra mile. When you get them back take the others out of the daily driver and send them when you feel like it. You wouldn't need them right away. There's a form online that you print and send with the injectors and you can even get him to pay pal after he is done.
1980 928 Auto
Old 06-17-2014, 07:27 PM
