928S24 wont start.....
Hey Pelicans,
It's been a while since I've been on the forum. Last summer, I finally got the supercharged 928S4 running, and running well. It ran like a bat out of H@!! until about three weeks ago (I was driving it as a daily), and started experiencing issues which puzzle me. I understand that 928's can kill batteries if left sitting for more than a week, but I kept mine charged (for the most part) to avoid that. On my way back from the office a few weeks ago, I noticed that the battery was dead, which required a jump. I figured that I had left an accessory on or something (i accidentally left the door cracked open in the parking garage all day.) Predictably so, I knew the car wouldnt start, and got a jump. I also noticed after starting the car that it had developed a knock which was quite loud (dont know if this is related). The knock quieted down after it got warm. That night after getting home, I charged the battery to full (using a noko Genius charger), and the next day it started, and I drove it to the office again. At days end, I went to start the car, and found that it would barely turn over, but it did, and after about 15 miles, the car started to sputter as if out of gas (it was low on fuel), and I thought that was the culprit. I never thought that it was electrical, since according to the voltage guage, it was putting out almost 14 volts. I pulled of the freeway to get some gas, and after about a mile the car started violently shrugging, until it just died. I tried to start it, and it behaved as if the batter was dead. Anyway, I happened to be very close to an auto repair shop, and asked the mechanic for a jump, but the car behaved exactly the same way. it would barely turn over (and the digital display would barely pixelate). Then the tow truck driver tried with his unit, and same thing. I suspected it could be a bad battery, or bad starter, and I checked both after getting the car home. Battery is 8 months old, and checked out with my voltmeter, and also a third party test showed it was fine. Then I removed the starter, and had it tested by alternator/starter specialist -It checked out fine. I verified that the grounds were tight, so I'm out of ideas. Can anyone point me in the right direction. The motor in this car is a replacement with low miles, and I replaced the oil pump, timing belt, CPS, knock sensors, put in a portensioner, and had the cams reground to factory specs before putting it into the car. Does anyone have any ideas? That knocking bothered me, but I dont think that is the problem. It seems like an electric issue to me, not a motor seizing. Always something with this car, and I'm at my wit's end with it. Thanks all for your insight. Last edited by Yellowb1rd; 02-06-2015 at 02:14 PM.. |
I'd try turning it over from beneath using a socket and lengthy breaker bar. That would definitively
tell you if the engine is tight or not. |
Network Native
Ground strap or ground points, ground strap an easy replaced item from Mark or Roger with a quality non Porsche expensive one.
Network Native
If its an automatic, check the flex plate and release tension on the clamp, measure crank end play.
Thanks for the tips, all. Definitely gives me something to look for. I think the ground strap is most likely the issue, but it looks fine at a glance. Bad grounding is the only thing I can think of that would cause the car to seem like the battery was dead (display pixelates and very hard starting - barely turning over).
The ground strap cannot be tested by "looks". What happens is, the connection inside the crimped end can be bad.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Network Native
Ground straps often look great, but an inch or two under the insulation its junk. Good replacements are cheap.
Hey guys,
I've finally had the opportunity to test the bad ground cable theory. I ended up swapping the ground cable from another 928 in fine running order, and still same issue. So the battery, ground cable, and the starter check out so far. I've even gone so far as disconnecting the stereo and alarm connections from the positive terminal, to no avail. Where else can I check? Incidentally, when turning over the car (I tried at dusk), I popped up the headlights, and they were very bright, but then went very dim while attempting to start it (along with the slow rrrr rrrrr rrrrrrr, and pixelated digital readout). Please help. Last edited by Yellowb1rd; 02-17-2015 at 05:14 PM.. |
Petie3rd
based on the info provided,
you need a new battery. Also pull the regulator from the alternator and inspect the brushes, if they are worn replace the brushes or replace the regulator with another Bosch unit . do not use aftermarket parts for the regulator
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
It seems be a faulty grounding issue; however, you bring up an interesting point - would a faulty regulator cause such an issue? Does the regulator 'amplify the output' when starting? Last edited by Yellowb1rd; 02-18-2015 at 10:56 AM.. |
You still haven't ruled out an issue with the engine internals. I suggested earlier taking a breaker bar and socket to the front of the engine. Before you waste money make sure the engine isn't tight.
And, that's it. I went out and checked it, and it will NOT turn over with my wrench and a 27mm socket. I've turned it by hand before just before re-installing the motor, and it rotated much easier, as I recall. Checked the oil, and it's VERY dirty, almost a dark greyish color, and smells of fuel. The oil only has about 700 miles on it, so it should not be that dirty. I really didn't want to believe it was another motor issue (this is engine #2). I've pulled two plugs (one on each bank) at random, and they seem fine, but I will need to drain the oil, and examine it, then pull the rest of the plugs (then try to manually turn it over again), and do compression test to be sure. Could be fuel lock...
Good luck I hope it's not serious.
Kool
Major bummer bro...got my fingers crossed for you...
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
Network Native
Frequent advice from Mr Merlin, drip some oil on a dark sheet of paper and look at it in the sun for sparkles.
SharkHead
'79 928, 85k Opal Metallic '99 BMW 540i, 97k Titanium '72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga |
Petie3rd
next step drop the bell housing,
take a picture of the front flex plate coupler, then release the clamp Bolt. then try to turn the engine. This is my best guess you have thrust bearing failure, though from your description it wasnt pointing to this. when you installed the engine did you tighten all of the pinch bolts on the drive shaft , including the one at the transaxale to 61 ft/lbs
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 02-19-2015 at 03:41 PM.. |
Petie3rd
well the pinch bolt that matters is the one at the trans axle,
if its loose then the whole shaft will migrate through the bearings and preload the front
Brian. |
Thread Tools | |
Rate This Thread | |
