Changing rear calipers!
I'm considering updating my rear calipers on my 1983 928 to the brembo ones from an s4. One of mine has seized.
Does anyone know what else I would need to do the conversion, apart from the calipers themselves? Thanks in advance-adam |
Considering the rear brakes do about 25% of the stopping why not just put standard replacement rears on.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
I've been offered a pair of s4 ones at a good price, so was seeing what sort of a job it was to use them!
You'll need small spacers to center the calipers over the rotors. I used four grade 8 flat washers when I did mine (don't remember the size, but it wasn't anything out of the ordinary).
And, of course, you'll need the correct brake hoses. Don't know what brakes you have on the front, but I've got a pair of "S" brakes (if you don't already have them) that would probably "balance out" the front and rears. See my Garage Sale post below. Depending on where you are, though, shipping may be a ***** - they're fairly heavy. James Last edited by jheis; 02-02-2015 at 03:12 PM.. |
Thanks for the info James! I have the s brakes up front, but may even go with the s4 conversion down the line! At least the rears seem a simple swap over, so may as well go with them! Thanks again, Adam! |
Take it, just the s4 standard brake pipes will do the job?!
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Yes, S4 brake hoses. And yes, same rotors.
James |
Interesting as the S4 Brembo swap on an OB "Fronts" require different Rotors. My 83 S on the other hand stop very well compared to my 81 Euro.
I don't think I replaced the rear rotors when I did the swap on my car, but I did it over 10 years ago, so my recollection may be wrong.
Along with different rotors, the front S4 Brembo swap also requires the whole S4 front suspension: upper A-arms, lower control arms, steering knuckle, tie rods, sway bar, etc. The whole geometry is different. James |
Thanks James,
The rotors listed on parts sites seem to all be the same up until 95, so that ties in! Thought the front may be a bit more involved, but didn't realise it was that involved! Thought it would be the hubs and Rota's but not the whole suspension set-up! Sent from my iPad using Tapatalk |
The kit I have for my 81 Euro is:
1) S4 Brembo Calipers 2) 997 Rotors <-- I think this was the model 3) S4 Braided lines 4) Special made overpriced adapters/mounting bolts 5) S4 Brake Pads I still haven't installed it all, it's been in boxes for about 4 years now. Someday I will get to it.
You can "back date" to the earlier (apparently up to '81) front suspension and use the adapters or "up date" to the S4 - which requires all the S4 goodies off of a donor car. James |
Probably 82 as well. 83 is the first S as I have one.
Does that include the shocks and springs too, to be swopped over, or can the originals remain! |
Not sure...
My '82 had the non-adjustable ride height Bilsteins on the front. One shock went bad, so I replaced them with adjustable ride height Bilsteins which - with the stock springs - jacked up my ride height - even when adjusted the whole way down - so I installed a pair of Weltmeister S4 springs. All this was before I converted to the full S4 set-up, so I was already running front S4 springs and shocks. Ultimately, I ended up with a set of Eibach progressive springs from 928 Int. If your car has height adjustable shocks on the front, you're probably good to go. James Last edited by jheis; 02-05-2015 at 12:32 PM.. |
I don't know If I'd run the S4 rears without the corresponding fronts. This will change your brake bias. How much I don't know. You could be in a situation where you locking the rears making it very hard to control especially in turns.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
I was running Ferodo "Premier" pads all around. When I needed a new set of front pads, my local parts guru recommended PBR "Deluxe Ceramic" pads. At an autocross, one of my buddies told me that I was locking the rear brakes before the fronts. On the street, it sometimes seemed like I was just going to roll through the intersection. With the PBRs it felt like I'd lost about half of my front braking "bite" compared to the Ferodos. Dumped the almost new PBRs and got a new set of Ferodos and all was good again. James Last edited by jheis; 02-06-2015 at 01:48 PM.. |
