EIPtuningR32's Avatar
Send a message via AIM to EIPtuningR32
Fuel Accumulator Question
is there any way to bypass a fuel accumulator? and is there any downside to doing so?
1982 928S euro M28/11
That criminal under the hood is a really bad influence on me: "hey...what about another 1000 rpm? And you know, we're doing 75...but I can go 100 and you'll hear my beautiful voice a lot better! Lets go baby..."
dammit! I'm such a slut~ N! -Normy
Old 05-08-2012, 01:03 PM
im tired of my car sitting... and i dont have $425 to spend on it
Old 05-08-2012, 01:04 PM
MPDano's Avatar
$200 Good Used at 928 Intl with a 1 Year Warranty.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-08-2012, 01:36 PM
high pressure fuel line and clamps wont work?
Old 05-08-2012, 01:41 PM
My 80 has never had one as long as I have owned it [ since 86].I never realized that until last november ,so what besides the accumulator have I been missing for the last 100k km? I would think that just a good check valve should suffice to keep the pressure in the line between startups.
Old 05-08-2012, 04:21 PM
Kool
AirtekHVAC's Avatar
I am intrested to hear more input on this...I don't know if mine is bad, but it sure don't look good....
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 05-08-2012, 04:47 PM
mine was bad. The car wouldnt start if it was hot, but it would if it was cold.
So if your car works without one, i assume mine would to... i think ill try the HP fuel line and clamps method.
Old 05-08-2012, 06:15 PM
JK McDonald's Avatar
Aux Toggle Switch -
Hey EIPtuningR32, The fuel accumulator is only installed to smooth out any minor fluctuations in your fuel pressure (similar to a shock absorber) as you drive your car and to maintain a residual pressure in the fuel lines after shut down to help during a restart. It is basically a canister with a rubber bladder in the middle, a spring in the top half and fuel stored under pressure in the lower half. There are many Bosch style fuel accumulators on the market that are interchangeable between vehicles. As long as the connections are similar and the internal capacity of an accumulator is relatively close – it will work. For example I often install one designated for a 6 cylinder Volvo on 911 Porsche – at half the price. Search on the internet under Bosch Fuel Accumulator rather then one for a specific model car and you’ll see lots of photos that will help in identifying a substitute. By the way the one needed for a Porsche, Mercedes, BMW - V8 engine is a big mother and they are all pricey....
If you are having trouble with your accumulator one other temporary option (until you buy a new one) is to install an axillary toggle switch to manually energize the fuel pump relay. This can often help during start up. Normally the fuel pump relay/fuel pump on a CIS injection car is initially turned on when the ignition switch is in the start position. Once running there is an small switch on the fuel control unit that looks for movement of the air control arm and keeps the fuel pump running. If your fuel line check valves are sealing properly and the accumulator is working, a cold or hot restart is normally no problem.
By temporarily installing an aux toggle switch to apply a ground to the fuel pump control relay, you can force the fuel pump to pressurize your fuel lines (negating the accumulator) before you even begin to apply the starter.
Please note – once you are running, turn the added aux toggle switch off. This allows air flow switch to control the fuel pump as the system was designed to do. The air flow switch is a safety circuit that will turn off the fuel pump if the engine shuts down for any reason.
Good Luck, Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 05-09-2012, 05:39 AM
Delete, at worst your starter might have to spin the engine for another second while the fuel pump pressurises the line prior to starting. cut off the threaded fittings and silver solder on a couple of olives. As you can see from the fuel staining where it used to live , car definately better off without it.
EDIT_ sorry, this pic shows more of the emmission hoses, better pic'on later post
Old 05-09-2012, 04:01 PM
Kool
AirtekHVAC's Avatar
Dang...I never thought of that....and considering I have rewelded mower decks with coat hanger rod, seems like something I would have come up with! I gots lots o silver solder!
Ron
Old 05-09-2012, 05:24 PM
Luis_M's Avatar
Plexus928: Consider replacing that 30r7 spec hose with something tougher, like EFI hose. You know the fuel pressure is about 75psi in that wheel well there....
81 928S Euro 5sp, 03 996TT X50 Tip, 02 Z3M S54 5sp
past favorites: 99 M3 E36 5sp
Old 05-10-2012, 07:30 AM
whatudrivin's Avatar
Get the 30R9 hose (100psi) or the Gates Hose with Green Shield. That stuff is good up to 255 psi.
\Brad/
'82 928 Automatic w/Competition Package Black/Red
Old 05-10-2012, 08:17 AM
Kool
AirtekHVAC's Avatar
good Eye Luis...I am in the process of redoing all mine, and did not catch that....I got the Gates Barricade stuff....not too expensive...got mine at O'reileys, but hate their clamps...
Ron
Old 05-10-2012, 08:55 AM
That Gates hose held enough pressure that the front face of my fuel pump blew out before any leaks or stress were noticed anywhere else.
\Brad/
Old 05-10-2012, 09:03 AM
OB Wan
Jadz928's Avatar
I heard you could substitute it for a coiled loop of high pressure rated fuel line. The coils basically make a "pee trap" to keep fuel up in the feed line once fuel pressure is released.
I've have no direct experience doing this. Do your research. YMMV.
Jim Doerr - 928 Classics http://928classics.com
'77 ('78), Preproduction Press Car, 9288100016, 'Number Six'
'78 US, 5 speed, #225
'78 Euro/RoW, 5 speed, #1075
'79 US, 5 speed, #0954
Old 05-10-2012, 09:50 AM
MPDano's Avatar
Geezus, remove those clamps and put FI Clamps on there. You cannot use those clamps on high pressure hoses.
Old 05-10-2012, 10:49 AM
are the olives necessary?
Old 05-10-2012, 07:19 PM
Kool
AirtekHVAC's Avatar
Plexus...what did you do for a fuel filter?
Ron
Old 05-10-2012, 08:37 PM
I agree with swaping the clamps,only ones I had available when doing a test set up. there are two lines there, the supply line (the one that is only about 8 inches long)is high pressure, the branded line is connected to the one way valve/emission, not pressure.
I left enough space when I cut off the threaded fittings for an in line filter, probably put one there when I uprate the fuel pump, at the moment have standard pump/filter set up.
You will need the olives, regardless of clamps, without the olive/shoulder there will be a risk of the line blowing off
Old 05-11-2012, 12:24 AM
Kool
AirtekHVAC's Avatar
Ahhh....I think I may have to do this...I wanted stock, but mine is so F'd up, that might not be feasible at this stage. Priority one is to get it to run and assess the mechanicals before I go full bore on it.
Ron
Old 05-11-2012, 06:26 AM
