engine rebuild
Hi
I am thinking of doing a engine rebuild on my 1986 928 s2.Does any one know of any good books that will help
Old 01-01-2016, 11:33 AM
Petie3rd
Mrmerlin's Avatar
well before you open the tool box lets find out why it needs to be rebuilt
Old 01-01-2016, 06:02 PM
stepson's Avatar
David,
These engines are normally very good upwards of 3-400K miles. What is there going on with your engine that would make you think it needs rebuilding?
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 01-01-2016, 09:37 PM
thurst bearing gone ,got another bottom end but dont know how good rod and main bearings are but thrust bearing ok
Old 01-02-2016, 07:53 AM
JK McDonald's Avatar
Aluminum Block -
Hey Dave - Sorry to hear about your thrust bearing problem. A while back when I was initially sorting through a couple of potential 85 - 87 models I almost bought one with a similar issue. Although I've not had to go any deeper into a 928 V-8 than the timing belt/water pump/oil pump/reseal etc... on the front, the heads on the top side and the oil pan/crank bearings/thrust bearing inspection from the bottom - if you have all the spec's I would assume that a rebuild or parts swap would be fairly straight forward.
The main question I'd have would involve whether to try and seat a new set of rings in the (Alusil) silicon impregnated aluminum block..... You may do best to keep the secondary block pistons and rings in their original bores. Just stay close with all the expertise and experience available on the 928 sites and take it slow. Here is a brief write-up on the block material -
Porsche 928 V8 Nikasil Cylinder Treatment | Kuhn Performance
It is just too bad that there aren't any instructional books on Rebuilding a Porsche 928 Engine around like there are for the air cooled 911 (Otherwise known as The Opposite-Mobile To The 928). The "Porsche 911 Performance Handbook" by Bruce Anderson and the "101 Projects for Your Porsche 911" by Wayne Dempsey make up the ultimate 911 Bible. They include a step by step guide into EVERYTHING you would ever need to know about rebuilding the 6 cylinder engine and keep it purring like a kitten. This type of critical information can save your butt and pocket book many times over.
By the way - If anyone has ever found this type of aftermarket technical publication on the 928 other than what is available in the factory manuals please chime in.
Good Luck, Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 01-02-2016, 01:23 PM
1985 Porsche 928s
I am building my '85 32-valve back up right now and have learned quite a lot along the way through research and the kind folk on this forum.
Continue to post questions and I'll pitch in.
Old 01-02-2016, 10:08 PM
Network Native
Danglerb's Avatar
When the thrust bearing goes it puts a lot of metal bits into the oil and typically less than 100% are caught in the oil filter with some going into all the nooks and crannies of the heads and other oil passages, lifters too. Bolting those parts on to a new short block even with a lot of cleaning may still leave metal that will work loose later on.
Check some thrust bearing threads to see how others have proceeded.
Old 01-03-2016, 04:43 PM
