Why I love this forum!
So, I have my 928S4 up on the lift while I wait for new motor mounts and also replace my oil pan gasket. After cruising around this forum I decided to check my flex plate since I have an automatic. Something I would have never known about if it wasn't for all the dedicated people who take their time to take pictures and post their knowledge on this forum.
After dropping the exhaust down a bit and removing a few bolts, I gained access to the flex plate. It "looked" good, but I put a straight edge on it only to discover it was putting pressure on my engine. Here is the before pic: ![]() ![]() I had a heck of a time getting the hex bolt loose. I soaked in Liquid Wrench, tried all sorts of things, made a tool out of cutting a spare 8mm allen wrench, and then applied some heat. That did the trick! Here is the tool I made: ![]() Once slightly loose, the flex plate popped perfectly flat and in place. I took out another straight edge and confirmed: ![]() Again, I would have never known what or how to check this if it were not for this forum. Thank you, Bob
I’m Porsche-less! 2010 AMG E63 - what an engine! BMW K1200R - Hang on! 1987 Porsche 928 S4 - SOLD. 1981 Porsche 928 Saved & SOLD. 1976 Porsche 911 S (V8 Race Car) - SOLD. Yes I'm blue collar, all my white ones got dirty! |
Great post!
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
now I would do a crankshaft end play check while you have it apart - there is a good write up here CRANKSHAFT END PLAY & THRUST BEARING HEALTH
how to do that - also you might want to get a proper tool to remove and tighten that clamp hex head bolt in and out - if you strip that out it's a REAL pain to drill it out - I know all about that from a 944 - and they come in handy for many jobs on these cars - harbor freight has a set of long metric allen bits for about $10
84 928 S - SOLD 2012 Cayenne S Last edited by honerboys; 02-08-2016 at 08:47 AM.. |
Petie3rd
dont forget that to do this properly also includes removing the rear pinch bolt and inspect the shaft cutout to see if its centered,
NOTE If the bolt has shank damage it should be replaced the torque spec is 66 ft/lbs add a drop of blue thread locker to the threads of the bolt
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
928 Junkie
Hey Bob
Good to see someone so close. Let me know if you need any local help. We have a small but active group in North Atlanta that gets together in all of the warm months.
Brian Phillips 1979 928 , 5-speed, cork interior 1982 Euro S 5-speed project 1985 928S, auto(sold)1978 Euro 5-speed (found another home)1983 928 s 5 sp short shifter black/black (sold)1982 928 auto (sold) |
Yes, buy a quality set of allen and torx bits. Your knuckles will thank you for it.
Plus, I doubt you're going to get anywhere close to 66 ft/lbs torque with that 1/4 inch adapter in the equation. Good luck, with the rest of your repairs. Brian. |
Northern
You need 3/8 and 1/2 ratchets for most of the work on the car. Sockets, extensions, and allen heads too.
87 928 S4 Indischrot - Siede Grau - Schwarz Leder - Unberührten Automatikgetriebe |
