nwebley's Avatar
Sorry.. Gauge / instrument cluster not working
Sorry guys I know this had been touched on a million times, but I can't understand what's happened to my gauge cluster.
Basically I have an 86.5 928 and it has given me such a headache and HUGE bills since I bought it.. but it's so close to working perfectly!
I was playing around with some fuses (as you do) and the gauge cluster was working perfectly before hand. I then went back and everything is dead on there (apart from lighting).. I cant help but think I must have knocked something and yes I checked the fuses relating and they are fine.
Any pointers? Also one of my solenoids seems to be a bit noisy, I assume it's gone bad?
Thanks in advance
1985 930 Turbo Dunkel Blue
1986.5 Porsche 928 Guards Red
1986 BMW M635 (EURO)
1983 VW Golf GTI (EURO)
Old 02-03-2016, 08:54 AM
nwebley's Avatar
Here is the headache in question!
Old 02-03-2016, 09:10 AM
honerboys's Avatar
I have seen where the actual fuse is good but the connection it makes to the upper and lower contacts is bad - try spinning the fuses or remove them and SLIGHTLY bend the contacts toward ach other - if all you touched were the fuses the problem should be there ...but it could be something else that just happened to coincide with your touching the fuses - also look at the ground connections above the fuse panel - make sure they are clean - there is a box under the dead pedal that controls the gauges - finally the ribbon connections in the pod are a weak spot in the system - good luck - very pretty car
84 928 S - SOLD
2012 Cayenne S
Old 02-03-2016, 09:37 AM
nwebley's Avatar
Many Thanks! I'll go through your list this evening.
Old 02-03-2016, 10:07 AM
nwebley's Avatar
Ground above the fuse panel! Thanks for your help
Old 02-04-2016, 04:58 PM
honerboys's Avatar
cool - I fast, cheap fix is always good
84 928 S - SOLD
2012 Cayenne S
Old 02-05-2016, 08:43 AM
