Sunroof lube
What's the best SUNROOF Lube anyway ? I read the White Lithium Grease can be used but well that attract Dirt and dust perhaps more ?
Then some better type ? Any input on such ? |
possessed
I've been using a silicone based lube...works well and doesn't seem to attract dust.
1988 Porsche 928 S4 ROW 1991 Toyota Hilux Surf SSR 1993 BMW 535i |
Kyle C
I read on LandsharkOZ that wax lubricant works well, such as bicycle chain lubricant. It goes on wet but dries to a wax. I purchased some through Amazon, but have yet to try it out. Search Amazon for "Finish Line Ceramic WAX Bicycle Chain Lube".
1974 911 1978 928 5spd hillclimb special 1984 928S 5spd, 1986.5 928S auto 1983 944, 1984 944 track car 1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S |
You have to clean the cables by removing mechanism if you want it to work right. 40 year old grease on those cables
82 928 Euro S 5 speed, sport seats,Moss Green/Champagne 04 996 C4S conv tip Polar Silver/Metropol blue |
The Wax Type Lube sounds Interesting have not heard of such before humm Before replacing the switch I did pull the Motor Cover and check out the Motor . I expect the shop Manual has a Procedure to get to the cables . Perhaps someone could Post it here that would be great . Tks all for the Tips |
Network Native
Wurth HHS2000 was what I figured was best last I considered it. http://www.amazon.com/Wurth-HHS-2000-Penetrating-Temperature-Lubricant/dp/B0002XRDLE/ref=cm_cr_arp_d_product_top?ie=UTF8
try this- made for the application
http://www.amazon.com/AUDI-SUNROOF-TRACK-GREASE-LUBRICANT/dp/B006R5QI4Y |
1985 Porsche 928s
Not an answer to your question but I had my seats out recently to clean the carpets and I lubed the threaded rod that moves the seat base back and forth, made a huge difference.
Administrator
A good synthetic based lube should work fine. For our Mercedes W204 project car it called for specific MB lube, which costs a lot as it's only offered in a big jug. We used a synthetic based lube with great results. Otherwise, we do have that VW/Audi lube HERE.
No, got lucky. A neighbor is a dealer tech @ Toyota and he had a partial tube of their lube- saved a buck, otherwise I would have used the VW/ Audi lube.
