Pete R's Avatar
Leaky power steering pump
My aluminum power steering pump appears to be leaking. What do you guys do? Is there a rebuild kit? What's the most economical procedure? TIA
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 05-27-2017, 11:08 AM
stepson's Avatar
There is a rebuild kit and although I've never had the pleasure to rebuild one, I have heard they are surprisingly easy and cheap to rebuild and have a high success rate.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 05-27-2017, 06:40 PM
Mal81's Avatar
Im currently running 100% of that Lucas power steering oil. No permanent solution (i have a rebuilt rack and pump waiting), but it doesn't complain 1 1/2 years later and doesn't leak any more.
1981 928 Euro "Babied and Pampered"
Old 05-30-2017, 04:28 AM
Pete R's Avatar
I managed to get off the pulley. There was just a hard seal behind it that I popped out. Hopefully I can put an new on in there and fix the leak.
Neon SRT4 track car
Old 05-30-2017, 06:28 AM
Crumpler's Avatar
Pete! How goes it?
How did this shake out?
On later pumps, the pulley is just bolted on to the spindle with 3, 10mm hex. I got no experience with the other versions.
There's a seal around the spindle that will fail, but you have to open the pump to get the circlip off, etc.
Rebuild kit pretty easy/fiddly, once everything pulled off...if you want to take it that far.
I apparently fubar'd the circlip the first time and had to go back in and replace it. That was my own fault.
Best, Dave
Dave
1986.5 Manual Blk/Blk
Old 06-23-2017, 06:27 AM
Pete R's Avatar
I recently had a surgery so I haven't finished. I just need to add fluids and fire it up. I found a seal kit but only changed the seal on the pulley shaft, I didn't dissemble the pump. I just did what was leaking. My catheter comes out Tuesday so I'll let you know how it went soon.
Neon SRT4 track car
Old 06-25-2017, 05:27 PM
