-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Jacking points 1984 928 S2 (http://forums.pelicanparts.com/porsche-928-technical-forum/973885-jacking-points-1984-928-s2.html)
tiger928 10-14-2017 06:37 AM
Hi All,
I've just ordered a trolley jack and a set of four stands.
I'm wondering the best places people use for the trolley jack and stands.
I've seen a 928 lift bar and im getting annoyed that we just dont get such items readily available in the U.K or EU. I do travel a lot to Germany and a few other EU countries so even have the option of collecting depending upon where from, but what use is this if they are so hard to find. I'm thinking of applying to the U.K government to have the UK moved closer to the USA!!!!
The lift bar is really nice but doesn't seem to be an option for me and i dont have unlimited funds for my car i'm afraid.
adam928 10-14-2017 01:57 PM
Hi fella, I use a trolley jack with a rubber jack pad on the original jacking points.. I've done this many times without any deformation of that area!! Once up in the air, there's a few substantial places to place stands... I tend to use the obvious load bearing points! I'm in the uk too, but have to found this site invaluable!!
tiger928 10-14-2017 03:32 PM
Hi adam928,
great, i will also use the usual jacking points then which i wanted to but thought i better ask here first. However is it possible for you to clarify the 'obvious' load bearing points as they are not as obvious to me!! Then i can use the jack stands without damaging the car or worrying i'm using the wrong places.
For some things i can just use 2 stands but i was thinking next time i change the oil i should jack it up and use 4 stands so the car is level when draining the oil or is this not really needed?
Shame we don't have the lift bars here, even though a little expensive they are so great, then easy to also use to place the stands.
thanks a lot for your info. i agree this forum is excellent
tiger928
