Question on flywheel differences
Hello all,
I have a question regarding the difference in 2 flywheels and don't have both parts in front of me so can't compare the two. Can a 1986 4.7S flywheel PET part no 928 102 075 01 for an M28.44 engine be used in a later 928 S4 5.0L M28.50 motor with the PET part no 928 102 075 04 I know the part no's are slightly different and obviously so are the engine sizes, however do the flywheels measure & weigh the same and have the same no of teeth? Any and all help greatly appreciated
Challenge your limits, don't limit your challenges 911 RSR Jagermeister replica (Sold) 1987 944 Turbo cup (Sold) |
Petie3rd
the 86 early flywheel is for a dual disc,
the S4 is single disc. 928 INTL lists two different parts so I would say they are not interchangeable
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 01-08-2018 at 09:15 AM.. |
Thanks appreciate the feedback
PCA Certified D.I.
The number of teeth on the ignition ring are different and will not allow the newer engine/chassis to run at all, for certain if it's an automatic. The later flywheel will not fit the earlier block with the starter mounts being different and no clearance. Maybe a spacer on the crank will allow it to fit, haven't tried that yet, but need to.
1986, '87,'88 928S4, 2006 Cayman S Cabluey, 2006 Cayman S "Burn Notice" |
