Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Need Help Identifying DME Chip
Does anyone recognize what chip this is? I found it inside my DME and I can't find any information on it.
Old 03-26-2019, 09:17 AM
Could be anything. Somebody may have copied another chip and put his own avery label on it.
Good luck, George Beuselinck
Old 03-26-2019, 11:20 AM
Oh darn. I was hoping it was some common chip that was obsolesced sometime back. Thanks for the help!
Old 03-26-2019, 02:14 PM
In the Fires of Hell.....
kdjones2000's Avatar
Not sure why you would have a 28 pin DME in an '87 car.
What is the part number on the DME?
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-26-2019, 09:50 PM
Sorry I uploaded the wrong pic. The actual one is the same sticker but It is a 24 pin.
Old 03-26-2019, 10:31 PM
That makes more sense.
Old 03-27-2019, 06:35 AM
soxnail's Avatar
What other mods are/were done to the car that may be related to the DME ?
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 03-31-2019, 12:26 PM
soxnail's Avatar
Looks like the board it's on is a standard '86 DME...
951.618.121.08
The part and rev number match.
Sox
Old 03-31-2019, 12:42 PM
Super Moderator
nize's Avatar
if you're feeling brave you might try peeling the sticker off and see what's underneath.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 04-01-2019, 10:30 AM
Wow thanks for all this awesome info! My car is totally stock apart from an aftermarket alarm and stereo. This was from a DME I bought off the eBay. I was just curious to see what it might be. The KLR I have doesn’t have the same sticker. I thought they would have the same branding on it because they should come in a set. I’ll take a look at what’s inderneath since I’m not planning on using the aftermarket chip anyway.
Old 04-01-2019, 11:13 AM
soxnail's Avatar
If you have a way of downloading the code in the chip, it can be compared with the original to display the differences.
Sox
Old 04-16-2019, 07:32 AM
I don’t have the hardware to download the data from the chip. I looked it up to see if there was an inexpensive way but gave up going down that rabbit hole. There are too many usb chip burners to chose from. Thanks for the insight!
Old 04-16-2019, 09:28 AM
soxnail's Avatar
Well if you really really want to know, drop it in the mail to me I will read it and create a diff file for you.
Sox
Old 04-16-2019, 12:38 PM
Nice. I appreciate the offer but it’s not that serious for me since I realize that I don’t have a matching KLR chip for it anyway. Thanks again!
Old 04-16-2019, 02:29 PM
