Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Help!: Noise from left rear
Hi,folks.
I have a problem my 951.
My 951 has mechanical noise around rear right side.
It sounds like it's coming from around the right rear tire.
fuel pump???
It stands out when it's cold.
so In summer season nothing, it just appears in winter season.
Appears while idling. of course the car is stopping.
Does someone get back to me let me know the causes about this noise.
It sounds like this " kan kan kan kan kan kan kan・・・・・・・・・"
Best
duck
Old 03-08-2021, 03:33 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Could you be specific about the outside temp, i.e. below zero? If so you may have ice crystals in the fuel pump that could have that effect on the pump. It might also be freezing in the fuel system causing the pump to cavitate.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 03-09-2021, 08:52 AM
thanks >mytrplseven
But the Outside temp is around 10 degree....
No Freeze.
Old 03-09-2021, 11:26 PM
Super Moderator
nize's Avatar
in the subject you say the noise is coming from the left rear, but in the description you say it's coming from around the right rear tire, which is it: left or right?
-do you hear this noise or does it change when the car is driving faster or slower than 20mph?
-do you hear this noise when the car is stopped and not moving at all?
-if you can hear the noise when stopped, can you get out of the car and locate exactly where the noise is coming from?
-can you post a video showing the area while it's making the noise?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 03-10-2021, 06:49 AM
Thanks Mr.nize
It's right side.
I'm sure no it doesn't. It's same sound.
Sure. the car is stopping and engine is running.
I think so. I'll try to hear under the car with lifting the car next holiday.
sure. I'll try it!
thanks
Old 03-11-2021, 07:14 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Originally Posted by us71 View Post
Hi,folks.
fuel pump???
Best
duck
Can,can? Burlesque dance? LOL! Bro it might be your muffler banging against something, if your stop, not stopping, its a exhaust issue. Fuel pumps make a "wizzzing" sound, so if its parked<correct grammar, and making your can-can noise, then its the exhaust pipe hitting something, due to a vibrating engine, go under the car and grab the cold exhaust pipe, and wiggle it left and right until you here the noise, and correct the issue.
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 03-30-2021, 02:11 AM
