Help!: Noise from left rear
Hi,folks.
I have a problem my 951. My 951 has mechanical noise around rear right side. It sounds like it's coming from around the right rear tire. fuel pump??? It stands out when it's cold. so In summer season nothing, it just appears in winter season. Appears while idling. of course the car is stopping. Does someone get back to me let me know the causes about this noise. It sounds like this " kan kan kan kan kan kan kan・・・・・・・・・" Best duck |
944 addict
Could you be specific about the outside temp, i.e. below zero? If so you may have ice crystals in the fuel pump that could have that effect on the pump. It might also be freezing in the fuel system causing the pump to cavitate.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
thanks >mytrplseven
But the Outside temp is around 10 degree.... No Freeze. |
Super Moderator
in the subject you say the noise is coming from the left rear, but in the description you say it's coming from around the right rear tire, which is it: left or right?
-do you hear this noise or does it change when the car is driving faster or slower than 20mph? -do you hear this noise when the car is stopped and not moving at all? -if you can hear the noise when stopped, can you get out of the car and locate exactly where the noise is coming from? -can you post a video showing the area while it's making the noise?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Thanks Mr.nize
It's right side. -do you hear this noise or does it change when the car is driving faster or slower than 20mph? I'm sure no it doesn't. It's same sound. -do you hear this noise when the car is stopped and not moving at all? Sure. the car is stopping and engine is running. -if you can hear the noise when stopped, can you get out of the car and locate exactly where the noise is coming from? I think so. I'll try to hear under the car with lifting the car next holiday. -can you post a video showing the area while it's making the noise? sure. I'll try it! thanks |
Kessel run in 12 parsecs!
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
