Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
soxnail's Avatar
Comression test numbers
I have a quick question for the brain trust...
I just ran a compression test and got the following:
#1 155 psi
#2 160 psi
#3 140 psi
#4 155 psi
The difference between highest 160 psi and lowest 140 psi is 12.5%, which is higher than 10% (number quoted often as being in specs).
My question is do I really need to tear into the head gasket/vales ect. for this differential ?
I don't wanna
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 01-11-2024, 11:40 AM
Arizona_928's Avatar
Throw some oil in number 3 and report back.
dolor et pavor
Copyright
Old 01-11-2024, 08:39 PM
Two things: Was the conmpression test done on a warm motor? Have you considered a leak-down test (will tell where compression is being lost)?
Peter
1968 912 SW Targa (Restoration: almost Tangerine again)
1986 951
2013 Cayenne Diesel
Old 01-12-2024, 05:58 AM
soxnail's Avatar
Did the "wet" teaspoon of oil in the cylinder, compression went up to 180 psi...
Looks like piston rings ??
Sox
Old 01-12-2024, 02:09 PM
soxnail's Avatar
Peter
Test was done on a cold motor, Will do a leak down test next.
Sox
Old 01-12-2024, 02:10 PM
Yeah. Rings are a little worn… almost a 40 year engine…
What’s your oil pressure? Burns oil?
dolor et pavor
Copyright
Old 01-12-2024, 09:45 PM
Sox
Is a waste if you got your compression up on a wet compression test. You know you don’t have a bad HG or burnt valves….
dolor et pavor
Copyright
Old 01-12-2024, 09:52 PM
soxnail's Avatar
concur, Will run a hot engine compression test after the car is running again.
Sox
Old 01-15-2024, 07:40 AM
dme dme is offline
Is it running badly? If not... let sleeping dogs lie.
Dan
86 Guards Red 951 (the best so far)
86 Black 951 (sold 12/31/09 PITA)
86 Guards Red 951 (sold in 7/15/00 (first love)
90 Plymouth Voyager, 2.5 Turbo 5 speed
Old 01-18-2024, 07:56 AM
soxnail's Avatar
It's running fine, just chasing a 12psi boost issue...used to be 14psi.
Sox
Old 01-20-2024, 06:27 PM
Super Moderator
nize's Avatar
i'm pretty sure the lower boost is not because of the compression issue because i've seen 951's with even lower compression making over 21psi of boost.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 01-21-2024, 08:01 AM
soxnail's Avatar
Nize, you are correct, it is not likely. I was just doing a general health check on the car. I also am getting the injectors cleaned and refurbished at the same time.
I am pretty sure the missing 2 psi are related to the massive leak at the ICV.
Sox
Old 01-21-2024, 09:04 AM
I just inked a deal on a new to me 89. I had compression testing done on it and it came back within 1% thank god. Gonna have a mechanic tear into it yet? ��
Old 08-11-2025, 07:18 PM
