Comression test numbers
I have a quick question for the brain trust...
I just ran a compression test and got the following: #1 155 psi #2 160 psi #3 140 psi #4 155 psi The difference between highest 160 psi and lowest 140 psi is 12.5%, which is higher than 10% (number quoted often as being in specs). My question is do I really need to tear into the head gasket/vales ect. for this differential ? I don't wanna ![]() Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Throw some oil in number 3 and report back.
dolor et pavor Copyright |
Two things: Was the conmpression test done on a warm motor? Have you considered a leak-down test (will tell where compression is being lost)?
Peter
1968 912 SW Targa (Restoration: almost Tangerine again) 1986 951 2013 Cayenne Diesel |
Did the "wet" teaspoon of oil in the cylinder, compression went up to 180 psi...
Looks like piston rings ?? Sox
Sox
Yeah. Rings are a little worn… almost a 40 year engine…
What’s your oil pressure? Burns oil?
Is a waste if you got your compression up on a wet compression test. You know you don’t have a bad HG or burnt valves….
Thanks Sox
Is it running badly? If not... let sleeping dogs lie.
Dan 86 Guards Red 951 (the best so far) 86 Black 951 (sold 12/31/09 PITA) 86 Guards Red 951 (sold in 7/15/00 (first love) 90 Plymouth Voyager, 2.5 Turbo 5 speed |
It's running fine, just chasing a 12psi boost issue...used to be 14psi.
Sox
Super Moderator
i'm pretty sure the lower boost is not because of the compression issue because i've seen 951's with even lower compression making over 21psi of boost.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Nize, you are correct, it is not likely. I was just doing a general health check on the car. I also am getting the injectors cleaned and refurbished at the same time.
I am pretty sure the missing 2 psi are related to the massive leak at the ICV. Sox
I just inked a deal on a new to me 89. I had compression testing done on it and it came back within 1% thank god. Gonna have a mechanic tear into it yet?
Thread Tools | |
Rate This Thread | |
