-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   951 Modification Number Question (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/141816-951-modification-number-question.html)
porscheboy16 12-30-2003 06:49 PM
What RWHP numbers would be estimated with the following mods:
1. Vitessi Stage II
2. 75 LB Injectors
3. Bypass Pipe
4. Evo BOV
5. Lindsey Racing Stage II Intercooler
This would be run on 93 Octane.
I am thinking about 340 RWHP, am I in the neighborhood?
1.2gees 12-31-2003 02:14 PM
You can be, but you're forgetting one important thing, how much boost you're going to run.
The 75lb injectors are on the large side, and not needed, also the BOV will make absulutely no power compared to a working stock unit. I would also save my money on the intercooler, plenty of people make that kind of power w/the stock unit. Infact there's a few people making over 400 to the wheels w/the stock unit...
Ahmet
porscheboy16 01-01-2004 07:41 AM
Sorry, I knew I forgot one thing, I'll run 16 PSI.
Fast951 01-01-2004 06:21 PM
Vitesse Stage II uses 55# injectors. At 16 psi boost you should be around 320-340rwhp. However, on pump gas it's recommended not to exceed 15psi boost
