951 Modification Number Question
What RWHP numbers would be estimated with the following mods:
1. Vitessi Stage II 2. 75 LB Injectors 3. Bypass Pipe 4. Evo BOV 5. Lindsey Racing Stage II Intercooler This would be run on 93 Octane. I am thinking about 340 RWHP, am I in the neighborhood? |
You can be, but you're forgetting one important thing, how much boost you're going to run.
The 75lb injectors are on the large side, and not needed, also the BOV will make absulutely no power compared to a working stock unit. I would also save my money on the intercooler, plenty of people make that kind of power w/the stock unit. Infact there's a few people making over 400 to the wheels w/the stock unit... Ahmet
Cheers! |
Sorry, I knew I forgot one thing, I'll run 16 PSI.
Vitesse Stage II uses 55# injectors. At 16 psi boost you should be around 320-340rwhp. However, on pump gas it's recommended not to exceed 15psi boost
John |
