Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Question New guy making 300 rwhp. Want more need help.
I just found this board. I have an 86 951. Huntley Racing stage 3.5 turbo, stage 4 MAF, HR exhaust, HR hard pipe kit, Monster BOV, apexi Boost controller, fuel pressure regulator. The car makes 291rwhp on the dyno but for some reason it would only boost 1.0 bar. On the street with the same settings it boosts 1.2-1.28 bar in 4th gear but I guess the dyno will not load the car the way the street will. Anyway, I guess the car makes about 320rwhp with full boost.
I have been considering taking the boost up a little higher. This car is not a daily driver so dependability is not an issue. What is the highest you guys boost your cars? Also does anyone know how to install a regular momo shift knob in a 951. You must need a different shift stalk to mount an aftermarket shift knob to.
I have several race videos and pics of the car on my site if anyone is intrested. www.garyjavo.com
Thanks.
Porsche 951
Old 08-17-2004, 02:39 PM
You're probably getting better cooling on your intercooler with the car on the road.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-17-2004, 02:49 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Welcome.....
I was running 15 psi most of the year.... I will run her at 18 psi when I get her back together.... I will probably run a couple of >20psi glory runs as well just for ****s and giggles.... but will settle back to 18 psi
Car looks very nice.
Which wastegate are you running ?
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-17-2004, 03:53 PM
I've been running 1.1 bar for almost 2 years. Or it could be 3 years, I forget.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-18-2004, 04:24 AM
Alex,
Thanks, factory wastegate. Looking to upgrade so I can squeeze out a little more boost. I talked to the guy at lindsey racing about his dual port bolt on wastegate for $400. What do you recommend?
Porsche 951
Old 08-18-2004, 07:09 AM
Ebs Ebs is offline
Your car looks absolutely stunning.
1986 951 Euro spec model
Anthracite on black
105,000 km
K&N, Lindsey Boost Enhancer, chipped, oversize fuel regulator
968 Club Sport anti sway bars
Adjustable Koni Yellows
Fuchs alloy : 9 inch rear, 7 inch front
2.5 inch stainless steel exhaust
1984 928 S2 (Jap spec)
1977 Mazda 323 - hard core tuned
Old 08-18-2004, 07:10 AM
ae1969's Avatar
Originally posted by Gary Javo
Alex,
You are more than likely loosing a little boost from the stock wastegate..... The original wastegate spring will definitely have deteriorated by now.
I run a Tial 38 mm ........ as good as it gets for the same price as lindsey wants for theirs. Some run Tial 46mm but I think thats a little overkill for our applications.
Old 08-18-2004, 08:56 PM
will944's Avatar
Send a message via AIM to will944
I run Lindsey's dual port and think it does a great job!!
Nice Car!!
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 08-19-2004, 01:06 PM
emwporsche's Avatar
I run about 18-21 depending (crappy $500 boost controller)
The highest I have run (i have similar mods but a few extras I think) is a boost spike at 24 psi
it made 355 rwhp and 400 ft lbs of tq
nice car.
you need the plastic cover for your tow hook and a splitter.
do you have chips for the car?
injectors?
Old 08-20-2004, 07:02 PM
What plastic cover?
I do have chips from HR.
I do not have injectors.
What would I have to do to make that much power?
Porsche 951
Old 08-21-2004, 07:48 AM
ae1969's Avatar
The tow hook has a little black plastic cover that covers up the hole in the front bumper. You can see it nicely in your first pic........Just follow the front porsche badge....
The splitter replaces the batwing (the underbody front cover under the front bumper). The splitter also sticks out at the bottom......like a lip.
The only problem with the splitter is that its fiberglass and not many last if you drive them on the road..... Doesnt take much to crack it.....
Gary...I can't recall what huntley used as a Stage 3.5 turbo ??? 18-24 psi on stock injectors with your setup is not a good idea. At that psi it may be out of its efficiency range (any specs on that turbo), egts would rise, stock injectors would not be able to keep up regardless of what fuel pressure you throw at them..... and then BOOM. hehehe
How was that dyno sheet you ran? Was there room for tuning things ? AF ratio etc ?
Old 08-21-2004, 08:44 AM
chapstic2001's Avatar
Send a message via AIM to chapstic2001
I have never been a fan of your wheels but your car makes them look damn nice. Very nice ride.
'08 BMW e90 335i 6MT stock [aka 'take two']
'12 Dodge Durango [family hauler]
'86 951 (K&N Cone, Welt Chips, Tial, Zeitronix, P&P O-ring PH Head, WFHG, AFPR) [in storage]
Old 08-21-2004, 08:47 AM
emwporsche's Avatar
injectors STAT!
Old 08-21-2004, 11:20 AM
Alex,
It's been a couple of years since I have done anything to the car. To be honest I built it and basically put it on the back burner while I took on a couple of new projects. Now that I am done with those I have focused back on the 951. I'm not sure of the specs on the turbo. I just remember Derreck telling me it would support up to 375 to the wheels. What kind of injectors should I get?
Chapstic,
Thanks.
I have HRE's on everything else (well almost everything else) but I couldn't bring myself to order a set for the 951. Personally I like a nice deep lip. 3" on the z, 3.5" on the viper.
Porsche 951
Old 08-21-2004, 11:40 AM
emwporsche's Avatar
I think that 55# injectors do fine up to about 350 rwhp before you would need to go bigger.
I have either seimens or delphi
Do you have an apexi avc r?
how do you like it?
what is tuning you MAF?
There is currently a groupbuy on Rennlist.com for wideband
Oh and you have some REALLY nice cars.
Are all of them yours?
Do you own a matress company?
Old 08-21-2004, 11:47 AM
EMW,
Yes I am running the Apexi AVCR. I think it's a good piece. I think the stock wastegate is the limiting factor. Hopefully when i get the Lindsey wastegate I will see a noticeable increase in performance. I am running the Huntley Racing MAF with their fuel computer box mounted inside and I have installed the "special" O2 sensor for their rich lean guage. I tuned the car with that stuff, took the car to the dyno and things were spot on. As far as the cars, the one's in my sig are what's sitting in the garage right now. The ones on the site are cars I currently own or have sold with the exception of my friends 996tt.
Porsche 951
Old 08-23-2004, 07:21 AM
emwporsche's Avatar
a new wategate will only help if the old one is draining boost in the higher rpms.
what kind of exhaust is it?
cat back?
from the turbo back?
after the down pipe?
Old 08-23-2004, 07:25 AM
Huntley Racing test pipe back to a Apexi muffler.
Porsche 951
Old 08-23-2004, 09:00 AM
Klaus Oberhiem's Avatar
Alex,
You need to dump the factory wastegate ASAP unless it was modified there is no way it will hold 15-18psi till redline.....forget the Lindsay and go with a Tial 38mm or 46mm....try Speed Force Racing as they sell the adapter kit to mount the Tial.
Old 08-23-2004, 11:19 AM
[i]forget the Lindsay and go with a Tial 38mm or 46mm....try Speed Force Racing as they sell the adapter kit to mount the Tial. [/B]
Thanks for the advise but they want $725 for the whole thing and that's more than wanted to put into it. What should I look out for with the Lindsey for $400?
Porsche 951
Old 08-23-2004, 12:09 PM
