Guest
Posts: n/a
Tach and Boost Gages out???
I just replaced the motor in my '87 951 and now the tach and boost gage don't work.... The motor starts and runs fine and strong, turbo spools well, etc... All other gages work fine and the tach and boost gages worked before. Is there a connector I missed for these items? Any ideas?? Thanks for your response!
-CKKrause |
It's the 4-pin connector behind the glove-box.
Guest
Posts: n/a
Thanks Danno! That clue led me to the fact I put an '86 motor into my '87 car and the connectors are different!!!! The main thing is that I got IT!! Thanks again!
-CKKrause |
Got it fixed yet? If not, I can take some pictures of my patched one if it would help.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Guest
Posts: n/a
Zero10-
Got it fixed and they work fine... Thanks for the advice over on Rennlist! -CKKrause |
Not a problem at all. It's funny that we were both in the same situation. Let me know if you have any luck on the oil level light. I seem to have some bad wiring somewhere.
