I picked up a rear hatch that was in much better condition than mine and it had a rear wiper installed on it. I would like to make the wiper operable with the factory controls.
I have the piece of harness that goes from the real cargo light area to the wiper motor and the factory rocker switch. I believe the rocker switch plugs into socket labeled 2 in the console. The problem is that I do not have any power to the switch socket. I have studied the schematics, but could not figure it out. Is there more hardware required, or is there a bridge jumper that needs to be installed. Any help would be greatly appreciated. Thanks, John
'86 951, MAF, K27, 46 tial, 3" ext '84 Audi Coupe '87 Audi 5000 QT (QLCC chip) '89 Merkur Scorpio 5 speed RIP |
I have studied the wiring diagram and there is a connection labeled, T1a that could be the problem. It is located near the fuse block, but I can not find it. Does anyone know where it is located?
Solved
I pulled the fuse block out and reseated the cable coming from the backup light and rear wiper fuse. Circuit is working fine.
