-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Most psi seen!! a 2.5 block take? (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/26001-most-psi-seen-2-5-block-take.html)
perfectchoicemotorsports 10-12-2001 08:04 PM
What is the most boost or psi, anyone has seen on a dyno run or boost guage, for a 2.5 liter block either Turbo or modified NA block?
Kevin
PCM Injection
wolfrpi 10-12-2001 09:04 PM
24-25 briefly
Erick
perfectchoicemotorsports 10-12-2001 09:13 PM
Wolf:
Was that boost or Absolute pressure?
Kevin
PCM Injection
Macabre 10-12-2001 11:21 PM
I've seen 20psi boost. 20-24psi absolute would be stock or less so I'm sure that means boost.
'86 951 Graphite Metallic/Tan
adrial 10-13-2001 06:11 AM
I know someone in Florida that runs 22psi in a 951...he knows someone that runs 40psi + NOS....
the 22psi car had a O-ringed head and wide fire headgasket...not sure what other engine mods. The 40 psi I have no idea.
dan10101 10-14-2001 06:51 AM
I've seen 21psi briefly with a stock block 2.5. I usually run 18psi. Currently working through the startup bugs on a new APEXi AVC-R boost controller. So far the most I've been able to get out of it is 17.
Give me another week or 2 and I'll do a writeup on it.
DanD
http://www.Boost-O-Holic.com
seb928s 10-14-2001 04:36 PM
Since we are on the boost subject what is an safe boost to run in an 951, that is stock no new gaskets or stuff like that?
951carter 10-17-2001 06:35 PM
you cannot raise the boost w/o chips or the DME will cut you off. With just chips i would advise @ 15 psi. I have run 24 psi before with a wide-fire gasket and a shaved head which raises compression slightly. All internals were stock at the time.
89-944NA 07-28-2012 04:31 PM
I hit 28.6lbs (hi boost recorded on my AEM tru-boost), running a k27/6 on a turbo s with stock internals, wastegate stuck closed. Damn happy I didn't send this engine over the rainbow bridge though. But damn, that was one hairy ride for a few seconds.
944chm944 07-28-2012 04:53 PM
someone here in colorado was running 30+psi on his old 2.5 engine
zedsn 07-29-2012 11:25 AM
I ran 20 psi boost briefly with autothority maf, autothority chips, stock fpr and stock injectors and it was fun. I do run 15 psi with a 3 bar regulator and performance chips for everyday driving.
running_cold924 07-30-2012 09:45 AM
also what are you running? 93? 101? 118? E85??
zedsn 07-30-2012 10:36 AM
At 15 you can get by with 91 but I don't chance it and run 93 always.
PAUERMAN 07-30-2012 11:45 AM
I run 1.5 bar (22 psi) daily and have been for the past 3 years. I use E85 fuel and my Vi-PEC engine management kit. Absolutely no problems and I know it will take more boost without any issues.
rick13 08-01-2012 04:17 PM
somewhat off topic. i personally witnessed 40psi on my fathers 2.3 liter Ford Mustang SVO. it had a cast iron block, head, and forged pistons...some multi-layer steel head gasket too.
somethings you never forget...
thank god for slicks!
blown 944 08-26-2012 01:10 PM
pressure is a small part of the equation. Having more boost does not always mean more power (most likely less).
I make a **** ton more power now with 19psi on this engine than I ever did at 35psi on the old one. To take advantage of more air coming in you need to address quite a few things first, otherwise it is just pressure for the sake of pressure.
This has all been documented through my 1/4 mile trap speeds over the years.
333pg333 09-03-2012 03:22 PM
I've hit 2 bar a few times by accident. Usually running E85. I like 2 bar, is very fast!!
968 GUY 09-03-2012 08:05 PM
How much stress can the rods and pistons take? I'm guessing more than the head gasket.
PAUERMAN 09-06-2012 05:18 PM
I just did a dyno session today with the 951. I've run 1.5 bar with E85 for a number of years and thankfully the car has been absolutely reliable.
Here's a couple of videos showing comparison runs using different timing values and just a regular run.
951 Timing Comparison
951 Dyno Run
ditch68 09-24-2012 08:20 PM
Very impressive, Vic! I still tell people about my ride in your car. Fantastic. What a beast!
Vic has an engine management system that just completely impressed me.
Jeff
