What is the most boost or psi, anyone has seen on a dyno run or boost guage, for a 2.5 liter block either Turbo or modified NA block?
Kevin PCM Injection |
24-25 briefly
Erick |
Wolf:
Was that boost or Absolute pressure? Kevin PCM Injection |
I've seen 20psi boost. 20-24psi absolute would be stock or less so I'm sure that means boost.
------------------ '86 951 Graphite Metallic/Tan |
I know someone in Florida that runs 22psi in a 951...he knows someone that runs 40psi + NOS....
the 22psi car had a O-ringed head and wide fire headgasket...not sure what other engine mods. The 40 psi I have no idea. |
I've seen 21psi briefly with a stock block 2.5. I usually run 18psi. Currently working through the startup bugs on a new APEXi AVC-R boost controller. So far the most I've been able to get out of it is 17.
Give me another week or 2 and I'll do a writeup on it. DanD http://www.Boost-O-Holic.com |
Since we are on the boost subject what is an safe boost to run in an 951, that is stock no new gaskets or stuff like that?
you cannot raise the boost w/o chips or the DME will cut you off. With just chips i would advise @ 15 psi. I have run 24 psi before with a wide-fire gasket and a shaved head which raises compression slightly. All internals were stock at the time.
Location: In a dumpster behind Albertson's in Los Angeles County
I hit 28.6lbs (hi boost recorded on my AEM tru-boost), running a k27/6 on a turbo s with stock internals, wastegate stuck closed. Damn happy I didn't send this engine over the rainbow bridge though. But damn, that was one hairy ride for a few seconds.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
someone here in colorado was running 30+psi on his old 2.5 engine
I ran 20 psi boost briefly with autothority maf, autothority chips, stock fpr and stock injectors and it was fun. I do run 15 psi with a 3 bar regulator and performance chips for everyday driving.
your average wrencher...
also what are you running? 93? 101? 118? E85??
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold )1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
At 15 you can get by with 91 but I don't chance it and run 93 always.
Got Turbo?
I run 1.5 bar (22 psi) daily and have been for the past 3 years. I use E85 fuel and my Vi-PEC engine management kit. Absolutely no problems and I know it will take more boost without any issues.
Vic Timpauer - www.pauertuning.com Mesa, AZ 944 Turbo S - Plug & Play Vi-PEC V44 EMS, GT3076R DynaPack Dyno: 358whp/352lbft @ 18.5 psi 91 pump 438whp/430lbft @ 22.5 psi E85 |
somewhat off topic. i personally witnessed 40psi on my fathers 2.3 liter Ford Mustang SVO. it had a cast iron block, head, and forged pistons...some multi-layer steel head gasket too.
somethings you never forget... thank god for slicks!
1988 944 turbo |
pressure is a small part of the equation. Having more boost does not always mean more power (most likely less).
I make a **** ton more power now with 19psi on this engine than I ever did at 35psi on the old one. To take advantage of more air coming in you need to address quite a few things first, otherwise it is just pressure for the sake of pressure. This has all been documented through my 1/4 mile trap speeds over the years.
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 |
I've hit 2 bar a few times by accident. Usually running E85. I like 2 bar, is very fast!!
Patrick Youtube 333pg333 86 modified 951 |
How much stress can the rods and pistons take? I'm guessing more than the head gasket.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
Got Turbo?
I just did a dyno session today with the 951. I've run 1.5 bar with E85 for a number of years and thankfully the car has been absolutely reliable.
Here's a couple of videos showing comparison runs using different timing values and just a regular run. 951 Timing Comparison 951 Dyno Run
Vic Timpauer - www.pauertuning.com Mesa, AZ 944 Turbo S - Plug & Play Vi-PEC V44 EMS, GT3076R DynaPack Dyno: 358whp/352lbft @ 18.5 psi 91 pump 438whp/430lbft @ 22.5 psi E85 Last edited by PAUERMAN; 09-06-2012 at 05:30 PM.. |
Incorrigible
Very impressive, Vic! I still tell people about my ride in your car. Fantastic. What a beast!
Vic has an engine management system that just completely impressed me. Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
