-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   3.2 litre build using the 1989 2.7 944na (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/297969-3-2-litre-build-using-1989-2-7-944na.html)
sker66 08-09-2006 09:08 PM
Has anyone done the 3.2 litre build using the 1989 2.7 944na engine as the donor? I am told you can resleeve the 2.7 block to accept J&E custom turbo pistons and a 3.0 s2 or 968 crank to come out with a 3.2 or 3.3 litre torque monster easily capable of 450 HP on street fuel while utilising the stock 951 turbo crossover pipe, intake etc.
Does anyone have any accurate info to offer ?
PS.......Is there any difference between the s2 3.0 crank and the 968 3.0 crank??
I was told that the 968 is a better piece!
thanks...........G
jgp0rsche 08-10-2006 06:06 AM
i haven't seen a 3.2L motor. however, I have seen a 3.1L, it had an S2 crank (which shouldn't be any different than a 968 crank), and 104.5mm sleeves/pistons.
It was built from an S2 engine and was a 16V turbo.
sker66 08-10-2006 07:06 PM
Was the guy happy with it?
Would you happen to have his contact info?
Geno
JivenJim 08-23-2006 01:25 PM
Came across most of what you were asking.
http://www.clarks-garage.com/shop-manual/951_eng_perfmod.htm
I think using a 3.0 block and then over bore, sleeve and using the 944 Turbo head/modified is easiest.
These guys can do it but it cost bank.
http://www.powerhaus.com/944t.htm
I have No first hand experience to share.
sker66 08-23-2006 05:03 PM
thanks............G
sker66 09-06-2006 04:39 PM
bump
Zero10 09-06-2006 08:29 PM
Chris White over on Rennlist should be able to give you a whole boat load of information on this.
IIRC he said it was theoretically possible to take it up to 3.6L or something crazy like that.
sker66 09-06-2006 09:08 PM
Thanks Chris
