| Registered Join Date: Jul 2006
				3.2 litre build using the 1989 2.7 944na
			Has anyone done the 3.2 litre build using the 1989 2.7 944na engine as the donor? I am told you can resleeve the 2.7 block to accept J&E custom turbo pistons  and a 3.0 s2 or 968 crank to come out with a 3.2 or 3.3 litre torque monster easily capable of 450 HP on street fuel while utilising the stock 951 turbo crossover pipe, intake etc. Does anyone have any accurate info to offer ? PS.......Is there any difference between the s2 3.0 crank and the 968 3.0 crank?? I was told that the 968 is a better piece! thanks...........G | ||
|  08-09-2006, 09:08 PM |
| Registered Join Date: Mar 2006 Location: FT MONROE, VA
			i haven't seen a 3.2L motor.  however, I have seen a 3.1L, it had an S2 crank (which shouldn't be any different than a 968 crank), and 104.5mm sleeves/pistons. It was built from an S2 engine and was a 16V turbo.
				__________________ 86 951 millenium yellow - show car 87 951 primer grey - track toy 88 944S guards red - 180WHP - SOLD | ||
|  08-10-2006, 06:06 AM |
			Was the guy happy with it? Would you happen to have his contact info? Geno | ||
|  08-10-2006, 07:06 PM |
| Registered Join Date: Oct 2005 Location: San Diego
			Came across most of what you were asking. http://www.clarks-garage.com/shop-manual/951_eng_perfmod.htm I think using a 3.0 block and then over bore, sleeve and using the 944 Turbo head/modified is easiest. These guys can do it but it cost bank. http://www.powerhaus.com/944t.htm I have No first hand experience to share.
				__________________ 1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles | ||
|  08-23-2006, 01:25 PM |
			thanks............G
|  08-23-2006, 05:03 PM |
			bump
|  09-06-2006, 04:39 PM |
| Registered |
			Chris White over on Rennlist should be able to give you a whole boat load of information on this. IIRC he said it was theoretically possible to take it up to 3.6L or something crazy like that.
				__________________ 2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! | ||
|  09-06-2006, 08:29 PM |
			Thanks Chris
|  09-06-2006, 09:08 PM |
