Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Boost Enhancer and Boost Controller
Can one run both at the same time, or is the boost enhancer a version of a manual boost controller? Just curious
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 09-26-2006, 07:45 AM
vott does ziss do?
ronin's Avatar
if you're speaking of the Lindsey Boost Enhancer, it is not a boost controller in the conventional sense. it simply helps keep the wastegate closed longer. you can still run an actual boost controller with the LBE. having said that, it is fine to run either one without the other or both together. they perform different functions
Old 09-26-2006, 10:31 AM
cold starter
JustinL's Avatar
If you want some mild mods, go for some chips and a manual boost controller. Bypass the cycling valve completely, that's what the KLR uses to roll the boost on and off. You must be careful not to overboost your stock chips or you'll know about it in a real hurry.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 09-27-2006, 04:20 PM
