Porsche Gonzo
Cluster Bulbs
Does anyone have a pic of the rear side of there instrument cluster like the one below... long story
Thank you
1986 928S (we need an excorsism done here) 1988 944 Turbo (2-14-2000 - 6-6-2008) Last Video Made in the 944 turbo (5-28-08) http://www.youtube.com/watch?v=UmjhT7AndEQ |
I have a couple extra clusters....... whats the problem?
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Porsche Gonzo
Well, i light tunnels have faded over the years, and i decided to redo the refective coating on the bottom of the tunnel. i also peeked inside and removed one of the bulbs and it was very clouded. i cleaned the bulb and then decided to clean all of them. one of the problems is that one of the bulbs didnt pass an ohmeter check and needed to be replaced... and one of them has a bluish white back on it... which can be removed with a small flat head screwdriver. i didnt write down which one it came out of because i assumed i would remember. when it was finished everything appears to work, but the odometer and trip meter arent moving although the speedo is. im concerned the bulb that died which has not been replaced yet was possibly being used to complete a circuit allowing the odometer to work...
sorry for the paragraph, does it matter where that bluish white bulb goes, and even then there are several empty bulb slots. i dont know maybe one of the cables was just loose Thank you for your response
Did you check out the worm gear and the little gear that mates with it. (Your earlier post about the instrument cluster) I would be very interested in finding out if there is indeed an electrical component to the odometer. Looking at my schematics and what I recall, I don't remember that.
Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
'83 911SC Cabriolet |
Porsche Gonzo
great pic thats actually exactly what i needed! right hand drive shouldnt make a difference so i will set them up again and see if that does it. thanks again pic was perfect
NP
