Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
JoshB's Avatar
In post #25 it looks like you are build a bar of boost by 3150 RPM and maxed out at 18lbs. AFR there looks dangerously lean too though right at 13? I am still trying to figure how all these numbers are supposed to work together. 323 with one bad cylinder and building boost that early is pretty impressive.
89 944 - Alpine white/blue, MSDS headers
Old 07-25-2008, 09:39 AM
Super Moderator
nize's Avatar
the boost gauge on the dyno is slow and reads one psi higher. i'm actually building 17psi by 2969rpm and running 17psi max boost, as you can see from datalogging on post 29.
i was intentionally running 13afr to see if it was worth it (it really wasn't worth the risk).
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 07-25-2008, 10:06 AM
Thanks, interesting read.
Did you run stock exhaust when you made the comparison?
Is the benefit in shorter spool up time enough to justify an upgrade for a car which will be running run stock boost and stock exhaust?
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 10-18-2009, 02:29 PM
Super Moderator
nize's Avatar
no. it was running the lindsey 3" exhaust, no cat.
probably not, but opinions may vary.
Old 10-18-2009, 11:37 PM
Super Moderator
nize's Avatar
photo links restored, and some updated info.
Old 08-11-2014, 08:13 AM
