Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
KLR to Manifold Line
Does anyone know the ID/OD and material of the line that runs from the KLR to the Intake Manifold banjo? I ask because I've tried to replace it a few times, napa, autozone, etc don't carry whatever this is exactly. It is hard to tell because mine is so old and brittle.
Old 11-12-2009, 08:47 AM
Super Moderator
nize's Avatar
you can replace that with a silicone line. lindsey sells a kit.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 11-13-2009, 11:11 AM
I actually have silicone line, from lindsey as a matter of fact. The problem is there is a pressure fitting at the actual KLR that a silicone tube will not fit - the walls are way too thick.
Old 11-13-2009, 11:16 AM
Super Moderator
nize's Avatar
use a thin zip tie to cinch that end.
Old 11-13-2009, 11:38 AM
I like it. Thanks
Old 11-13-2009, 11:39 AM
All Spooled Up
While on the subject, I have a question. Does the presence of oil in that line indicate a problem? Or is it simply another symptom of worn turbocharger seals?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 11-14-2009, 05:11 AM
Super Moderator
nize's Avatar
oil in that line is bad as it could mess up the boost reading the KLR sees. it means you're getting oil in the intake, which could be worn turbocharger seals, or oil blow-by from the crank vent.
Old 11-14-2009, 11:09 PM
All Spooled Up
Could it still be blow-by if compression is >145psi in all cylinders?
Old 11-15-2009, 06:01 AM
Super Moderator
nize's Avatar
yes. you can tell by checking the crank vent line where it recirculates to the intake for oil.
Old 11-17-2009, 01:52 PM
