changing to the 180 mph cluster
If i change the 160 mph cluster in my 86 951 to a 180 mph from a 88 951 will it fit with no problems and give me a correct reading???
probably. the signal is read by the dme. i have an '86 DME in my '88 and it works fine.
Hopefully it will work....
i remember reading a writeup on this somewhere on rennlist. i remember reading it won't work without some adjustment.
Don't know about compatibility, but the Speed sender goes directly to the gauge and not through the DME.
Sox |
hmm... that's interesting. on another thread, someone stated the opposite. but i trust sox more than the other source.
I run a 180 mph speedo on my 86'.........and it is accurate to 1 mph upto 120 mph. I did not test past that speed.
Plug and Play GPS verified. |
would it be just the wiring and the setup in the speedo that converts it to a speed reading. so there would be no adjustments at all. switching between a 180 to a 160 or vice versa. that is what i would be thinking. since there is nothing in between them. i would think the germans would have engineered somthing like that.
Thanx I probably be switching mine out soon...
let us know how it goes. :)
sox, i just realized i have a proposition for you.
oh no, i can hear the bells.... ;)
Sorry Nize I am already taken :)
Whats up Sox |
| All times are GMT -8. The time now is 10:35 AM. |
