-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   need help on camry problem (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/382930-need-help-camry-problem.html)
waltermiez555 12-17-2007 05:41 PM
SmileWavySmileWavySmileWavyran bad ,hesitates,stalls won't start at all now.thought it was bad gas but added dry gas and filled up when very low.last time i got it started i had to clean the plugs first,they looked fouled.makes me think problem is ignition also tach goes to 0 instantly when motor dies.92 toyota camry 4 cyl.any ideas greatly appreciated
nize 12-17-2007 06:04 PM
asking for camry help in a porsche forum? okay, just an idea: why not ask for camry help in the toyota forum? :)
waltermiez555 12-17-2007 06:45 PM
you know i did that. just trying to get as many ideas as posible.i also own a 944s and didn't know porche owners would be so snobby.
nize 12-17-2007 06:54 PM
so let me get this straight, toyota owners won't tell you how to fix your toyota and that's okay. but when porsche owners won't tell you how to fix your toyota they are snobby?
what 944's do you own? post up some pics and we'll tell you how to fix them all day long.
waltermiez555 12-17-2007 07:18 PM
don't want to deal with someone that doesn't have anything to bring to the table.i worked as a mechanic for many years, owned alot of nice cars but never refused anyone any knowledge i had if they asked.i think the problem with my camry is an ignition ignitor which all cars with breakerless electronic iginitions have,i just wanted to see if anyone else felt the same before i bought one.
davepnola 12-17-2007 08:12 PM
Jump out tc and e1 in the diagnostic connector , count the engine light flashes and get the code . Ps: if it has too many codes to count then un hook the battery cables for the battery positive and negative touch them together for 30 seconds reconnect try to start for a minute or to then jump out the diagnostic connector agian and count the engine light flashes. These cars were famous for distributor failures ( built in coil and igniter in the distributor) Also make sure you never jumped time ( T-belt) 2 nd a 3rd generation Camrys are some of the best built cars ever !! Bottom line , let me Know Davepnola,,, ex Toyota Tech .................................. Oh after u get the code then just type it into GOOGLE U know 92 camry with code 52 and hit enter someone will be talking about it !!!
waltermiez555 12-17-2007 08:25 PM
thanks davepnola i will try your idea and let you know.might be after xmas.this is the help i expected from fellow CAR PEOPLE.thanks again.
nize 12-19-2007 11:14 AM
i could use some help with my yamaha seca 550, any takers?
or how about my audi 5000s quattro? it's a german car too.
myskyon 12-19-2007 12:07 PM
here is for your audi : http://forums.pelicanparts.com/vw-audi-technical-forum/
and your yamaha well i would not ry to HIjack someone elses thread, you could allways try to post up a question about it somewhere on here.
gees
F18Rep 12-20-2007 11:00 AM
You guys are better than the funnies. Bruce
88BlueTSiQuest 12-20-2007 02:14 PM
Anyone know what I should set the valve lash on my Ducati to? And where can I find the shims cheap?
onehot951 12-28-2007 06:55 PM
good point nize. its true by fact that they both have engines and 4 wheels, but i think other than that, and both having a gas cap, the similarities end there. in all seriousness it sucks the toyota guys couldnt help you, i ran into problems like that when i had a merkur. however, in nize's defense its not that were being snobby, its just that the question was asked in a porsche forum. if i were to ask the ferrari guys how to troubleshoot an electrical problem on a mg midget, they would probably respond with a similar comment.
then again if i asked someone with a ferrari about an mg and "electrical problems" they would probably whisper the word "lucas"
at this point i think lucas wired the space shuttle....... GO Atlantis... oh darn another damn power connector problem... scrubbed!
