![]() I just started to tear into the clutch job. Starter, waste gate, heat shields, and exhaust is all out. Heading back to the trans axle now. It appears to be straight forward but why do I need remove the crossover pipe? Clarks says to take it off with the intake bla bla. Does it have to come off even when I can see the bell housing bolts ?? |
Nize ???
Nize, you of all 951 men must know the answer to this one
winter-hater club member
give it a try and let us know what happens.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
![]() ok I'll let you know, are you guys setting me up fro the practical joke here ? maybe I just have not seen "why" the crossover needs to come out yet And at this moment I don't feel like being under the car anyway.
In the Fires of Hell.....
I haven't gone through the Clark's Garage procedure, or done this yet on my car. However, there are two different procedures to use, one if you have the single-piece crossover pipe (More involved), and a simpler one if you have the two-piece.
One other thing to consider: I have heard that those upper bell housing bolts are very difficult to get to. You need some extensions and a universal joint. Removing the crossover may be required to get enough room to work effectively on them. Cheers, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
this might be an even stupider question... but can you not get the crossover pipe off without taking the intake manifold off on an 86?
'86 951 Guards Red, MBC, Adjustable FPR, Venturi Delete, LR Exhaust |
i got the crossover off of my '88 without removing the intake. it should be the same, i would think.
Super Moderator
heheh, i've currently been busy removing my motor so i haven't had much time to check in here as frequently.
i'm not 100% sure, but i think leaving the crossover in place might make it difficult to remove the bellhousing, and later to align the new clutch properly. you can remove the crossover without removing the intake manifold.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Super Moderator
i've been thinking about this some more, and i'm wondering if maybe the wastegate is what actually needs to be removed for a clutch job, and to remove the wastegate you have to remove the crossover (or exhaust/muffler).
here's a photo of the motor removed with exhaust manifold and crossover in place; ![]() and a head-on view of the bellhousing that must be removed;
yeah, it does look like the wastegate could cause problems.
The crossover only has to come off if you have the early '86 version. The later versions had a shorter connection for the wastegate and a separate elbow pipe.
Keith Belcher '87 951 nautic/cancan |
