Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
88turbos's Avatar
where should I start??
I just picked up a 88 turbo s and am tryin to figure out where I should start as far as upgrades. Any recommendations???
Old 09-30-2008, 12:41 AM
Super Moderator
nize's Avatar
welcome to 951 ownership! does it run okay? have you already checked the vac lines and hoses? can you post some more details about your car? is it stock?
these threads might get you started;
Porsche 951 (944 turbo) reference list
What next mod would net the most hp?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 09-30-2008, 08:33 AM
I wanted to be sure my 87 was running well in stock form before I did anything, so I did the following:
Belts.
Replaced all vacuum lines, big and small.
Replaced all coolant hoses.
New radiator, water pump, thermostat, fan switch, turbo temp switch.
Replaced 3 fuel lines in engine bay.
Replaced oil pan gasket.
Replaced intake and exhaust gaskets.
Rotor/cap/plugs.
New konis all round.
Fixed leaky power steering (by swapping to new manual setup).
Checked discs/pads for wear - OK.
Bled brakes.
Replaced one bad wheel bearing.
Replaced one bad engine mount.
Fresh gear oil.
I'm reasonably confident I now have a solid base to at least put some miles on the car. Once I get used to it I can evaluate what the next steps are. If you jump in and start upgrading without addressing the "boring" stuff, you can be chasing old gremlins and confusing them with upgrage gremlins. Don't take the sellers word that the car is perfect, he was trying to sell it.
1987 951 ROW
Old 09-30-2008, 10:31 AM
88turbos's Avatar
I went through it and all the belts, gaskets, ect have just been changed out about 5000 miles ago and the car only has 75000 original miles. I was just at the shop today and had it looked over. The car had been babied by an older doctor lady who was the original owner. It was in good enough shape to make the 6 hour drive home from orlando with no problems. It is all stock except fot the 3'' exausht I had thrown on. Other than that everything electronicly works. Even the old blackpaunt deck and EQ.
Old 10-02-2008, 01:04 AM
Super Moderator
nize's Avatar
looks like a great find, post some pics!
Old 10-02-2008, 08:53 AM
