-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Catch Can install - should I drill the AOS a bit ? (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/446110-catch-can-install-should-i-drill-aos-bit.html)
Champagne 12-12-2008 09:45 PM
I'm installing a cheap ebay kit for $20, should I drill the AOS out a little when I install the catch can?
I do NOT want to pull the AOS and drill, but I will if it is required.
TIA
Techno Duck 12-13-2008 07:08 AM
If your venting the catch can to atmosphere its probably not a bad idea. Not necessary on a recirc type.
I would consider going with a recirc type so you keep a proper vacuum on the crank case.
Champagne 12-14-2008 10:34 AM
Thanks Techno. I am reciculating the line back into the J boot.
